Will a 2006-2009 4.0 fit in a 2005 Mustang
Old 07-07-2013, 10:15 AM
rivets
rivets's Avatar
Default Will a 2006-2009 4.0 fit in a 2005 Mustang
My Mustang threw the timing chains so I have to replace the engine. Lot's of 06-09 engines available but will they fit in a2005 auto? I know the flex plate and torque converter are different but is that the only difference?
rivets is offline
Old 07-07-2013, 10:29 AM
THS_Steed06
THS_Steed06's Avatar
Rivets,
'05-09 are all basically the same car. If you have a 2005 V6 then any engine from that range will fit.
Why do you think flex plate changed in 06', was this part of an engineering change?
Tom
THS_Steed06 is offline
Old 07-07-2013, 12:35 PM
rivets
rivets's Avatar
Tom
The two clues are that all the wrecking yards list the 2005 engine as being unique and this thread indicates that at least the flex plate is different.
https://mustangforums.com/forum/4-0l...n-05-09-a.html
rivets is offline
Old 07-07-2013, 01:05 PM
MustangFirstCar
MustangFirstCar's Avatar
My question is why would you replace it with another V6? Do a V8 swap if you can. You can probably find a 4.6 from a GT and drop it in. You won't even need to do much to it if you use a complete engine from a GT and you have an auto, and it would be even easier if you found a GT in a scrapyard with all the necessary parts, like the rear end, driveshaft, computer, etc.
MustangFirstCar is offline
Old 07-07-2013, 01:39 PM
THS_Steed06
Wow! Ok that TC looks vastly different in that other post. Good luck with your motor swap.
Maybe 2005 motors won't be hard to find so you can keep your tranny parts?
Tom
Old 07-07-2013, 03:01 PM
jimkaray
jimkaray's Avatar
Anything different is going to be on your old motor so I wouldn't worry about it.
jimkaray is offline
Old 07-11-2013, 06:12 AM
akdoggie
akdoggie's Avatar
The 05's were different in the TBI, but otherwise, other than 1 sensor, I don't remember anything else we switch when I helped out a friend with his engine. He blew out the rt side chain cassette, so it was remove the engine. While we had it out, he found another engine from an 08 from somewhere and we switched it out. I just don't remember us having any big problems with the exchange. Both were 4.0's, and automatics. We even updated his to the later TB so he didn't have the hose heater piece. Much cleaner setup and worked flawlessly. Good luck.
akdoggie is offline
Old 11-09-2019, 07:42 PM
Ericada Parks
Ericada Parks's Avatar
Default Mustang
I have a auto 4.0 mustang and I bought a wrecked mustang from a junk yard for it’s motor but the car is a Standard will it still work with my automatic transmission
Ericada Parks is offline
Jgabbard
05-08-2018 03:37 AM
'stangdude
08-12-2015 01:27 PM
StangMuscle
08-12-2015 07:27 AM
daytooday
08-11-2015 09:22 AM
ericunderwood
08-11-2015 03:40 AM
Quick Reply: Will a 2006-2009 4.0 fit in a 2005 Mustang
