Hot Rod Cam Problem
Old 07-07-2013, 08:09 PM
ODDYSEY
Site Moderator of Fury!
ODDYSEY's Avatar
Default Hot Rod Cam Problem
Anyone heard of a camshaft sprocket breaking (or falling apart) when removing the cam phaser bolts?
I am having cams installed and when pull the cam phaser bolt, the sprocket was free spinning and the guide pins were sheered off.
Was curious if anyone else had that problem or heard of it?
ODDYSEY is offline
Old 07-07-2013, 08:33 PM
JCON
JCON's Avatar
I have not done a cam install but in my time on here and other forums, I have not heard of this issue. Did the sheer look fresh or old?
JCON is offline
Old 07-07-2013, 08:52 PM
Lem-06
Lem-06's Avatar
during my install i was hand turning the engine and the passenger phaser wasnt torqued down, just kinda hand tightened and the pieces holding it together snapped and threw the chain off, looking at how they were put together there is VERY little material holding them together so it makes sense they will easily break, guess ya can just replace them, once torque'd down it should prevent breaking, it probably broke when you broke the bolt loose
Lem-06 is offline
Old 07-07-2013, 08:56 PM
ODDYSEY
ODDYSEY's Avatar
That makes sense, but at $250 bucks it's an expensive lesson. Grr.
ODDYSEY is offline
Old 07-08-2013, 07:12 AM
Ford_Dude
Ford_Dude's Avatar
IMO get the timing set kit
http://www.americanmuscle.com/frpp-c...it-0510gt.html
I got this when I had my heads swapped, good thing too one of the tentsioners was crapped out
I don't know how many miles you have but the kit is likely a good idea more so if its higher mileage
Ford_Dude is offline
Old 07-08-2013, 09:14 AM
Ford_Dude
Ford_Dude's Avatar
Also depending on mileage get this too
http://www.americanmuscle.com/frpp-3...rce=igodigital
I'm liking my stage 3 HT heads
And after the costs that piled on I really should have gotten the hot rod cams at the same time, as the dyno joe said that over time the rollers take on an impression with the cam that if I wait to long he'd recommend replacing the rocker arms again.
But right now I have new rockers arms, new timing chains, tensioners, sprokets, cam actuaters (pretty much only thing on the heads not new is the cams) (even new one piece spark plugs, E3 just because I like that I won't have to regap them ever)
Old 07-08-2013, 02:55 PM
Lem-06
Lem-06's Avatar
your telling me....
i didnt have time to re-time the motor once the chain let go, so i had to get it towed to my uncles shop to re-time and replace the phaser, expensive lesson..
Lem-06 is offline
Old 07-08-2013, 08:59 PM
ODDYSEY
ODDYSEY's Avatar
Well it's all done, FRPP throttle body, intake, and hot rod cams. I love the way it sounds and shakes at idle, totally changed the feel of the car.
ODDYSEY is offline
Old 07-09-2013, 08:32 AM
Ford_Dude
Ford_Dude's Avatar
Hay oddy I found a place that does dyno runs for $75 for 3 runs, and its not far from this area.
I'm thinking of going there next week, you want to meet me there and see how our cars compair?
Old 07-09-2013, 08:33 AM
Ford_Dude
Ford_Dude's Avatar
Quick Reply: Hot Rod Cam Problem
