Rear differential leaking oil out of vent
Old 07-09-2013, 10:52 AM
abrush
abrush's Avatar
Default Rear differential leaking oil out of vent
I am at a loss as to why my 9" trac loc rear end is blowing oil out the vent tube so I am hoping someone might have a fix. I put a brand new Quicks Performance 9" rear end in my 65 Mustang last Spring with a trac loc 3.50 gears. The vent on the axle housing sits in the exact same place as the factory 8" rear end therefore I connected the hose exactly like it was done on the old rear end. I filled the differential until fluid started coming out the fill plug. I have driven the car at least 500 miles and gear oil is still coming out the vent and now I am worried I am low on fluid and will have to refill. I have been unable to figure out why it is doing this. I have no rear end noise. Does anyone have any suggestions as to how to fix this issue?
abrush is offline
Old 07-09-2013, 11:02 AM
LynnBob Mustang
LynnBob Mustang's Avatar
You only need around two and one half quarts of diff fluid in the rear end, how much did you actually put it?
Lynn
LynnBob Mustang is offline
Old 07-09-2013, 11:05 AM
clowe1965
clowe1965's Avatar
You can put a cheap fuel filter in the vent line near the axle to act as an air/oil separator.
clowe1965 is offline
Old 07-09-2013, 11:17 AM
abrush
abrush's Avatar
Lynn
I filled until it came out the fill hole and I'd say it took right about that amount.
abrush is offline
Old 07-09-2013, 11:53 AM
67mustang302
67mustang302's Avatar
Probably over filled it. You actually want it so the fluid is just a tiny bit below the fill hole. Because of the high viscosity and surface tension in gear oil...if you fill it till it comes out of the hole it's actually slightly above the hole and you end up with an extra 1/2 or more quart.
67mustang302 is offline
Old 07-09-2013, 12:29 PM
musnicki
musnicki's Avatar
When the oil gets hot it expands. I would wait until the hub is cold and check the oil level again. You should be able to fit your pinky finger in there and touch where the oil level is right below the hub plug opening.
James
musnicki is offline
Old 07-09-2013, 02:06 PM
gjz30075
gjz30075's Avatar
I had the same problem recently. Turns out that spiders had nested in the hose, blocking most of it, and I didn't realize it when I installed the hose. Blew out the hose and all is well now.
gjz30075 is offline
Old 07-10-2013, 07:05 AM
Al Newman
Al Newman's Avatar
Aside from what has already been suggested, I would ask what kind of gear oil you used. Recommended is GL-5 or GL-6. Automotive synthetic oils on the market today would be acceptable, but I would not recommend them for a new setup like yours. There is a lot of GL-2 floating around out there, and that stuff is for really heavy equipment. It foams up badly and could possibly be what is causing you to lose lube from the vent tube.
Best,
Al
Al Newman is offline
Old 03-02-2020, 12:35 PM
ActorMike
ActorMike's Avatar
I made a video that shows how to replace the vent valve-
ActorMike is offline
JonnyBlazeGT
11-03-2015 01:10 AM
Urambo Tauro
09-07-2015 12:47 PM
Itzjoe
08-26-2015 08:15 PM
91StangOwner
08-20-2015 11:34 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: Rear differential leaking oil out of vent
