2006 Ford Mustang
Old 07-10-2013, 08:40 AM
ccnmustangforums
Former Sponsor
ccnmustangforums's Avatar
Exclamation 2006 Ford Mustang
interior will be finished and roll bar painted before sale also fog light delete covers installed car comes with race stars or bullitt wheels with nitto drag radials.
Above Added: Sat July 6, 2013, 10:48 pm EST
Power:
Stock 4.6L
FRPP hotrod cams
FRPP twin 62mm polished throttle body
Whipple 2.3 HO supercharger w/ 3.25 pulley (11-12 psi)
Relocated IAT sensor to Whipple manifold
Seimens Deka 60 lb injectors
SCT BA2400 MAF w/ 90mm housing
OEM fuel rails
FRPP GT500 fuel pumps
Kooks long tube headers, o/r H pipe
Flowmaster mufflers
Drivetrain:
PI 3500 stall
TCI Servos
TCI Hardened input shaft
Auto transmission
FRPP 3.73s
Suspension/tires:
Cobra jet frond and rear springs
D-Spec adjustable shocks
UPR K-member
UPR front sway bar delete
BMR adjustable street/strip LCAs, BMR UCA & HD Brace
BMR adjustable panhard bar and brace
15 x 4 Racestar skinnies and MT sportman front tires
15 x 10 Racestar and MT Street Drag radials (275/50/15) rear tires
Look good/cool stuff:
V10 water pump pulley
2 90mm idler pulleys
100mm pulley
8 rib conversion, all pulleys aligned with Gates laser system
Gates HD "green" belt
Thumprr HD tensioner w/ 90mm pulley
Mishimoto radiator
Dual fans on heat exchanger
Moroso PS tank, Overflow tank, brake master cylinder cover fuse box cover
Stainless steel braided hose covers
K&N breatherson valve covers
Trans catch can
Relocated oil filter to drivers side frame rail increases capacity to 7 qtrs.
Lightweight battery
Large capacity heat exchange tank
CDC Aggressive spoiler on bumber
Turn signals, tail lights, rear side markers & 3rd brake light are all tinted
Red LED interior map lights
OEM rear spoiler
Roush hood scoop
SOS triple pillar gauge pod
Autometer triple dash pod
TCI auto shifter w/B&M handle w/ OD button in handle
GT500 pedal covers
Shaker audio system
Dynotech 1 piece aluminum driveshaft
BMR drive shaft safety loop
Dash gauges included: innovate AFR, autometer cobalt oil press, fuel press, water temp trans. temp, boost vacuum
PA 130 alternator
Re-badged with V6 emblems
SCT handheld tuner with current Dyno tune and emissions tune
6 point roll bar w/ swing out door bars
through the floor sub connectors
ADULT owned since new on lot in 2006.
Has NEVER had any hail damage and is always garage kept it has NOT been a DD
http://www.collectorcarnation.com/Fo...html?aid=32797
ccnmustangforums is offline
Old 07-11-2013, 04:31 AM
Narin Billa
Narin Billa's Avatar
Hey dear i have a 2006 Ford Mustang with a stock stereo that says its MP3 compatable but I cannot find anywhere to plug in my iPod. Does anyone have any suggestions for me?
Narin Billa is offline
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
NTO_GUY
12-24-2015 11:23 AM
08-10-2015 01:44 PM
Quick Reply: 2006 Ford Mustang
