Separator Plate Buzz/Rattle in Automatic?
Old 07-12-2013, 09:40 AM
richmod
richmod's Avatar
Default Separator Plate Buzz/Rattle in Automatic?
I have a very loud buzz/grinding sound coming from tranny area at low rpm when car is cold (although it seems to be doing it even when warm lately). I have checked for losses exhaust hangers, cat shields, etc - nothing.
I have read the TSB on the separator plate issue on manual trans, and my prob fits that description exactly. there is a very abrupt quality to the start and stop of the buzz - very much like a woodpecker on a metal gutter (had that on my house - not fun to wake up to).
I got under and looked to see if I could use a rubber washer on the bolts or silicone between the plate and bell housing as some people did with the manual trans. But it looks to me like the auto trans plate is different than the manual plate - the manual plate actual comes all the way down to the bolts, while the auto trans does not - it is shorter and higher up. the auto trans has a black dust shield thing that the bolts screw into. I took that off and looked up, and that separator plate comes very close to the flywheel (or whatever you call it in an auto trans)- I can see where it may contact it if it warps due to temperature.
Has anyone else had this problem with an auto trans? What is the cause? Any advice?
richmod is offline
Old 07-12-2013, 02:00 PM
jpplaw
jpplaw's Avatar
Does it happen at around the same RPM everytime? I have a weird noise like you described, usually at around 1800-2000 RPM in OD on moderate accel. Been there since she was new and have never been able to track it down.
jpplaw is offline
Old 07-12-2013, 02:21 PM
richmod
richmod's Avatar
Usually occurs on light throttle around that rpm - 1800-2000. Will sometimes occur even after taking foot off gas, but usually on throttle. It's getting loud. Doesn't happen when cruising - usually only when slowly accelerating from a stop within the first few seconds.
richmod is offline
Old 07-12-2013, 07:11 PM
jpplaw
jpplaw's Avatar
If you find out what it is, post it up.
jpplaw is offline
breaking
10-02-2015 01:27 PM
mdg
10-01-2015 07:04 AM
UrS4
09-30-2015 10:13 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Separator Plate Buzz/Rattle in Automatic?
