01 mustang v6
Old 07-12-2013, 09:43 PM
04goat
04goat's Avatar
Default 01 mustang v6
My son in law has a 01 mustang v6 3,8 the engine light came on and the code is p1285 i just replace the thermostat my water pump is working the temp is staying is the same place where it belongs but it is still giving me that cold i am not using any antifreeze can any one help with this plz
04goat is offline
Old 07-13-2013, 06:23 AM
LilRoush
LilRoush's Avatar
If it's not overheating, it could just be the temp sensor failing you.
LilRoush is offline
Old 07-13-2013, 10:54 AM
04goat
04goat's Avatar
where is the temp sensor
04goat is offline
Old 07-13-2013, 11:36 AM
LilRoush
LilRoush's Avatar
Front end of the lower intake in the coolant passage.
Also, just a suggestion - run a 50/50 coolant/water mix. Straight water will eat up the water pump, rust out the heater core and destroy the head gasket at the coolant port between the lower intake and the heads.
LilRoush is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
chain
08-17-2015 08:52 AM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 01 mustang v6
