94 gt spark knock
Old 07-14-2013, 01:51 PM
90notchback90
90notchback90's Avatar
Default 94 gt spark knock
Hi guys,
I just picked up a nice 94 gt 5 speed with 90k miles. It's been drivin maybe 100 miles in the last year. When I tach out a gear it spark knocks the more Tom's the worse it gets. Maybe it's old gas? Any ideas? Thank you
90notchback90 is offline
Old 07-14-2013, 07:06 PM
clowe1965
clowe1965's Avatar
TOM'S?
Guessing some autocorrect bs happened. When does it knock, just at the top? Go ahead and put some fresh gas in it, not like its going to hurt anything. Have you done any maintenance yet?
clowe1965 is offline
Old 07-14-2013, 07:49 PM
JimC's Avatar
Wrong section - moved from S197 5.0 section
JimC is offline
Old 07-14-2013, 08:25 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
seafoam it, check where base timing is set and run premium gas
mjr46 is offline
Old 07-14-2013, 08:51 PM
90notchback90
TOM'S?
Rpm's not Tom's.. No maintenance yet just got it a few hours ago.
Old 07-14-2013, 08:53 PM
90notchback90
Thanks, I will do that along with a full Tune up.
Old 07-15-2013, 05:41 AM
90notchback90
What are the correct steps to sea foam a 94 gt? I know some people just pour it in the gas but I'm guessing a need to run it through a vacume line while its running? Thanks
Old 07-15-2013, 07:09 AM
while the engine is running pull the break booster vacuum line . A lot of people just pour it right in I like to use a small kerosene funnel or something so its not so tricky to get it in the line. Its gonna smoke , ALOT. And if you pour it too quickly the engine will stumble and die.
Old 07-15-2013, 07:23 AM
clowe1965
clowe1965's Avatar
Let the engine warm up then you pour in 1/3 of the can, let the engine suck it in. Easiest to pour the 2/3 into the gas tank, then suck up the remaining third. After the seafoam is sucked up shut the engine off. Best to get a second person to shut it down and give it gas while sucking it up to keep it from dying.
Don't forget the fuel filter, it can cause problems too.
Old 07-15-2013, 11:43 AM
mjr46
mjr46's Avatar
on the back of the can it has all the directions, I often use the can that has a nozzle that allows the intake to draw it in after the Maf
mjr46 is offline
Quick Reply: 94 gt spark knock
