Help please 73 grande starting by it's self
Old 07-15-2013, 12:42 PM
michaelyerry
michaelyerry's Avatar
Default Help please 73 grande starting by it's self
I have been restoring this car for two years, it had been running great for about a year the other day the battery died on so i went to jump the car the car started as soon as the jump cables were hooked up the keys were not even in the ignition. I thought it was the ignition switch so i changed that today but the same thing keeps happening. I need to sell this car to get a car that is better for a college student. Please help!
michaelyerry is offline
Old 07-15-2013, 12:53 PM
120mm
120mm's Avatar
Starter solenoid stuck "on".
Starters are relatively cheap. Have it tested at the local auto parts place (they do it for free) or just buy a new one.
120mm is offline
Old 07-15-2013, 01:54 PM
jimkaray
jimkaray's Avatar
The starter relay (not technically called a solenoid when mounted remotely) is stuck closed. Give it a sharp strike with a screwdriver handle and it should unstick it. You'll find it on the fender apron right behind the battery. The short positive cable runs to it and then a long one down to the starter. Get it replaced asap.
Here is an http://www.ebay.com/itm/1969-1970-1971-1972-1973-FORD-MUSTANG-MUSTANG-GRANDE-STARTER-SOLENOID-RELAY-/390612388355?pt=Vintage_Car_Truck_Parts_Accessories&hash=item5af2500a03&vxp=mtrone so its top dollar, should be $15 - $20 at your local AP store or RockAuto.com
jimkaray is offline
Old 07-15-2013, 05:37 PM
120mm
120mm's Avatar
Here is an NOS one so its top dollar, should be $15 - $20 at your local AP store or RockAuto.com
Oops... you are right. They are dime a dozen and pry the most common thing to go wrong on the Mustang and I've replaced a bunch of them.
They are fragile, though. Don't wrench on them too hard.
120mm is offline
Old 07-15-2013, 05:45 PM
DocSnickers
DocSnickers's Avatar
solenoid or a ghost
DocSnickers is offline
Old 07-15-2013, 06:50 PM
boogerschnot
boogerschnot's Avatar
I vote ghost..
boogerschnot is offline
Old 08-27-2013, 02:23 AM
Sonic Mustang
Sonic Mustang's Avatar
It's self??? You must be attending a two year junior college.
Sonic Mustang is offline
Old 08-27-2013, 06:45 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
And you must be the resident douche who thinks he is much smarter than he actually is.
fastbackford351 is offline
Old 08-28-2013, 12:38 PM
Sparkiewalt
Sparkiewalt's Avatar
I have the exact same car...had same problem...after 2 new solenoids I figured out that the wire going from my solenoid to my starter was too small, I replaced with the same size as ran from battery to solenoid. the smaller wire was causing extreme heat that was destroying my solenoids.
Sparkiewalt is offline
Old 08-28-2013, 02:20 PM
67mustang302
67mustang302's Avatar
So this is where I mention that if you're going to quote someone, you should use quotation marks. Did you not learn that at your institute of higher education?
Grammar **** grammar fail.
Smart *** smart fail.
67mustang302 is offline
Quick Reply: Help please 73 grande starting by it's self
