Is my engine ruined?
Old 07-18-2013, 06:42 AM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Why did you drive the car for so long without an oil change?
I'm wondering if this is a joke as well.
You can go quite a while in between changes if you DON'T drive the car but I wouldn't wait a yr even then!
WHY did you do this?
Blacksmoke is offline
Old 07-18-2013, 06:43 AM
CaptainStr8edge
CaptainStr8edge's Avatar
ummm.... Try reading the code maybe??
CaptainStr8edge is offline
Old 07-18-2013, 06:45 AM
steel pony
steel pony's Avatar
7 posts in almost 2 years....maybe the OP was too busy driving their car to ask for advice...
Or maybe we should say Welcome back MarkNieb!
https://mustangforums.com/forum/5-0l...-this-car.html
I'm going to be chuckling all day now..
steel pony is offline
Old 07-18-2013, 06:46 AM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
BTW I've heard of engines being ruined just from startup and a couple of minutes of idle without oil.
I fear the worst for that engine.
Odds are definitely its gone.
Still waiting on WHY you did this.....
Very curious.
Old 07-18-2013, 07:52 AM
Nuke
Nuke's Avatar
So that would be just shy of 25,000 miles. IF you were using Amsoils 25k mile rated oil and IF you were having the oil analyzed every 5k miles and IF you were checking and maintaining the oil level (like any NORMAL car owner) then you would have been fine. Did you not check the oil over that time frame? Are you... challenged?
You really ARE joking, right? If not then, yes, then I'd agree that your engine is likely #%^*ed.
Nuke is offline
Old 07-18-2013, 07:56 AM
S197GT07
S197GT07's Avatar
Yea, he went too long without changing the oil, however.
The real question, is how you burnt through 5 quarts in 25k miles....
S197GT07 is offline
Old 07-18-2013, 08:12 AM
POWERMAN_
POWERMAN_'s Avatar
Doubt he's gonna respond after seeing everyone's reaction when the truth came out..
One can only wait and see.. ^_^
POWERMAN_ is offline
Old 07-18-2013, 08:15 AM
moosestang
moosestang's Avatar
That is the real question. Even after 47,000 miles and most of them supercharged, my motor doesn't use any oil. I catch a few ounces in my catch can after 3,000 miles, so the most you'd consume is 1 quart through the pcv valve.
This sounds like a joke. It's hard for me to believe that any mustang owner is this mechanically challenged.
moosestang is offline
Old 07-18-2013, 08:44 AM
  #19
Roy_R
Roy_R's Avatar
That engine flush storie was funny!!!
Roy_R is offline
Old 07-18-2013, 08:51 AM
  #20
RWDtech
RWDtech's Avatar
Originally Posted by zmanm3
Don't listen to these guys, oil changes are just a gimmick that big oil and car companies use to get you to spend more money. Engines don't even need oil anymore because most engine builders coat all the parts in Teflon.
hahahah I like how the stage 4 lurker from 2006 with only 3 posts, chimes in with a little trolling on this thread!!
RWDtech is offline
Quick Reply: Is my engine ruined?
