I need more ideas about drivers seat / cig lighter failure
Old 07-22-2013, 03:19 PM
chuck34984
chuck34984's Avatar
Question I need more ideas about drivers seat / cig lighter failure
2000 convertible, v6.. Lost power to both by simply plugging in a phone... I have pulled and check every single fuse both under hood and under dash..all look good..Checked lighter connection under console for shorts etc.and all appears good... seat too low and back to gain access to even remove seat or see much though the plug appears good also...
Now I'm at a loss, plus cannot seem to find a wiring diagram with these components listed.
Any ideas would be appreciated...
chuck34984 is offline
Old 07-22-2013, 08:36 PM
Daehawk
Daehawk's Avatar
I cant think of a thing except a fuse under the dash. Did you pull and actually check each fuse with tool or juts look at them?
Daehawk is offline
Old 07-23-2013, 09:02 PM
Sometimes you cant see a blown fuse simply by looking at it, I always use a multi meter and check for voltage on both sides of the fuse. There is a little spot on the top of each fuse designed to probe no need to remove them .
Old 07-24-2013, 01:07 AM
chuck34984
chuck34984's Avatar
Using a test light I see all the fuses both under dash and under the hood are good..
Found #1,listed as cigar under dash, has no power (fuse good).
Now I need to figure where it gets its power...
wileec
09-11-2015 10:16 AM
wenmill
09-11-2015 07:07 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: I need more ideas about drivers seat / cig lighter failure
