Replacing Leaf Spring Bushings
Old 07-23-2013, 06:47 PM
unit91
unit91's Avatar
Question Replacing Leaf Spring Bushings
I've been able to find some rudimentary instructions about this, but I have a couple questions I hope you can help with.
First, none of the instructions say anything about removing the wheels/tires. Are you supposed to leave them on while doing this?
Second, one set of instructions said to grease the bushings, bolts, inside of the front spring eyes, etc. What type grease? Regular lubricating grease like you'd lube your front suspension with? White lithium grease? What? I'm using rubber bushings.
Thanks very much for any guidance you can give.
unit91 is offline
Old 07-23-2013, 07:03 PM
67mustang302
67mustang302's Avatar
Here's how I'd do mine (and have in various forms in the past).
Jack it up and support the car under the chassis, NOT the rear axle. Get a spare jack stand that you can put under the rear axle to do 1 side at a time.
With a jack under the rear axle just slightly, unbolt 1 end of 1 side....driver spring eye, or driver shackle etc. Lower it down with the jack, it should clear enough to remove the bushing and be resting on a jack stand (though it will also hang on it's own from the other 3 points). I've found the easiest way to pull them out with grip the outside lip with a channel lock and twist it back and forth as you pull it out. Be careful not to bang your hands, and you may need to pry them out a bit too.
The shackles are a bit more challenging because you have to slide the shackle out 1st to drop the rear spring down and replace the bushings in the frame rail. Like sturdy screwdrivers and small prybars help here. You might also need a spray lube if they weren't previously lubed.
When installing, I use anti-seize and lube every part of the bushing that contacts metal. So on the front spring eye, the flat part of the bushing that contacts the bushing on the other side of the same eye, the outside that slips into the spring eye, and once it's in the face of the bushing that will contact the pocket (or shackle if in the rear). On the spring eye I lube the outside and inside of the metal insert and slide it into the bushings. And lube the shafts and inside faces of the shackles/plate.
Then just the rear up until either the spring is in the pocket or lines up to slide the shackle in. Slip the bolt/shackle through and tighten it (lube the threads too). Might have to push it around a bit with a pry bar to line it up or use a pin/large punch through the bolt hole. The shackles don't have to be torqued since the locking nut seats on a shoulder, run it up until it bumps the shoulder then make is hand tight. Torque the front though, since the pocket clamps the bushing, too loose and the suspension can walk in the pocket, too tight and it will limit the bushing from rotating.
Do 1 end of 1 side at a time. So like driver front spring eye, then driver rear shackle, then switch to the other side. That way when you jack the rear back in place it pretty much lines the spring back up.
If you're using poly, use stock rubber bushings on the shackles, it actually does make a pretty big difference.
67mustang302 is offline
Old 07-23-2013, 08:03 PM
unit91
unit91's Avatar
like Permatex Anti-Seize Lubricant???
like Permatex Anti-Seize Lubricant ???
(lube the threads too). Permatex Anti-Seize Lubricant ???
what's the ft lb torque for this???
Sorry for all the questions but I've never done this before and I don't want to screw it up.
Thanks very much.
unit91 is offline
Old 07-23-2013, 09:08 PM
67mustang302
Yeah, I just use the larger bottle of the Permatex stuff with the brush built into the cap. Easiest to work with since anti-seize gets all over the place if you look at it funny.
I think the torque on the front spring eye is like 50-55lb-ft or thereabouts. Don't quote me on that, it's in the shop manual though.
Old 07-24-2013, 09:25 AM
unit91
unit91's Avatar
Thanks very much. Should the wheels be left on or removed, or does it matter?
unit91 is offline
Old 07-24-2013, 09:57 AM
Boogie's_AutoRama
Boogie's_AutoRama's Avatar
Take the wheels off.
Also, when ever I'm doing any suspension work I put the weight of the car back on the springs before tightening/torquing the bolts. Either with a floor jack or on the tires themselves.
Good luck, let us know how it turns out.
Boogie's_AutoRama is offline
Old 07-24-2013, 10:14 AM
unit91
unit91's Avatar
Thanks for all the help! If I survive this operation I'll let you know.
unit91 is offline
Old 07-24-2013, 01:48 PM
unit91
unit91's Avatar
I'm assuming that I can jack the car up using the differential until I get the jack stands under the chassis?
unit91 is offline
Old 07-24-2013, 03:04 PM
67mustang302
You can leave the wheels on it you want, but it'll be easier with them off....they get in the way. It'll prolly take less time to remove them than work around them.
If you lube everything up real good then it's not necessary to load the suspension before torquing, since the bushings will be able to freely move. It doesn't hurt to do it though.
And yes, you can jack it up under the diff, that's how I usually do it. You can set the jack stands under the jacking locations forward of the leaves...you just want them clear enough of the front spring eye pocket to be able to work. Do NOT place them under the floorboard of the rear. Put them under jacking locations (notches), frame rails, load bearing locations etc.
Old 07-25-2013, 07:09 AM
unit91
unit91's Avatar
Started soaking bolts with penetrating oil. Noticed that the nuts for both leaf eye ends are facing to the outside - easy to get to. But the shackle nuts are all on the right side for both shackles. Does it make any difference which side the nuts are on? Facing the outside makes them easier to get to.
unit91 is offline
Quick Reply: Replacing Leaf Spring Bushings
