07 A/C control switch issues
Old 07-24-2013, 05:35 PM
07 Cervini
07 Cervini's Avatar
Default 07 A/C control switch issues
Ive search for a solution for this problem but I havent found a post anywhere about it. When I start my car I will turn on the A/C and select what direction I want the air to blow (far right ****). Sometimes no air will come out of the vents, regardless what fan setting i put it on or what air direction I choose. I also do not hear the "ticking noise" that sometimes is caused by the door actuators. I leaning towards the dash control unit going bad, but replacing that is over $300 dollars at Tousley Ford and I dont want to spend that much money on a gamble. When the system does work, it performs flawlessly. Any ideas on what it could be? Thanks.
07 Cervini is offline
Old 07-24-2013, 05:40 PM
AJSpags
AJSpags's Avatar
I have an extra control unit I believe. Let me know if you are interested.
AJSpags is offline
Old 07-24-2013, 05:58 PM
Could be the switch you are turning or it could be the blend door actuator itself. You can spot it behind the glove box if you drop it down and unhinge it. It's to the left of the opening
http://iihs.net/fsm/?dir=336&viewfile=Temperature Blend Door Actuator.pdf
I'd bet on the actuator itself but that's only because I've seen more of those go out than anything else.
Nick Oliver
10-17-2018 04:22 AM
Dragonus18
09-09-2015 01:21 AM
zanemoseley
09-06-2015 12:58 PM
Emblazoned
09-03-2015 10:45 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: 07 A/C control switch issues
