07 GT UPR catch can mounting.
Old 08-23-2013, 04:40 PM
70monte
70monte's Avatar
Default 07 GT UPR catch can mounting.
Guys, I need some pictures of where you have mounted this can on a 07 GT. We just bought one for my fiancée's car and I can't find a place to mount it. Her car doesn't have any holes in the place shown in UPR's directions and even if there was, there is this black looking piece mounted below it so the can would hit anyway. The support bracket is too short to mount it to one of the strut tower studs because the can hits the side of the tower and you cannot tighten the bolt down. I'm about to just install it without mounting it but I don't know if it will be stable or not. I talked to someone at UPR and he was supposed to send me a pic today of one mounted on a 06 GT but he hasn't yet Thanks for any help.
Wayne
70monte is offline
Old 08-24-2013, 06:55 AM
Scott2
Scott2's Avatar
Not a UPR, but a JVC catch can. I think the UPR is a little bigger, in my opinion mounting it directly in between the intake and valve covers makes the cleanest installation. Should fit as there is a PCV in the path in my picture (came with the supercharger) that you don't have if you are NA.
Scott2 is offline
Old 08-24-2013, 08:57 AM
Esch
Esch's Avatar
Here is where I mounted mine. I took out the stock black screw at this location and got a hex head bolt with nut and washer to mount it. It's easy enough to unscrew the canister to empty it, and it's pretty much out of the way IMO. Hope this helps.
Esch is offline
Old 08-24-2013, 11:54 AM
danzcool
danzcool's Avatar
Just used one of those wire/bendy things and didn't attach it to anything.
danzcool is offline
Old 08-25-2013, 06:52 PM
70monte
70monte's Avatar
Thanks everyone. That gives me some ideas on where to mount this thing. What is everyone using for hose? I've read a few places not to use the hose provided since it doesn't stand up to oil and will collapse under vacuum.
Wayne
70monte is offline
Old 08-25-2013, 08:27 PM
Esch
Esch's Avatar
Wayne
I used this stuff http://www.ebay.com/itm/Stainless-Steel-Braided-1500-PSI-10AN-AN10-10-AN-Oil-Fuel-Gas-Hose-Line-Foot-/121150175318?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c351cf856&vxp=mtr. I'd verify first that it's 10 AN, but I'm pretty sure it is. Then I just used blue hose clamps on each end.
Esch is offline
Old 08-26-2013, 02:55 PM
70monte
70monte's Avatar
Thanks for the link. The provided hose has an 5/8 ID so I'm sure the one in your link is the correct size. Is there anything special needed to cut that stuff since it has that covering on it?
Wayne
70monte is offline
Old 08-26-2013, 05:24 PM
Esch
Esch's Avatar
Wayne
I was fortunate enough to use my dad's bench grinder which has a thin cutting wheel on it. I put electrical tape on the area I cut to keep the fraying down.
Esch is offline
Old 08-30-2013, 04:40 PM
70monte
70monte's Avatar
I mounted mine in the same place as Esch did. Here is a picture.
Wayne
70monte is offline
Old 08-30-2013, 05:24 PM
Esch
Esch's Avatar
Looks good!
Esch is offline
Quick Reply: 07 GT UPR catch can mounting.
