Got a weird one - Vacuum lines
Old 08-23-2013, 06:18 PM
Darkcrime
Darkcrime's Avatar
Default Got a weird one - Vacuum lines
Long story short, I had to do an engine swap. The new engine from a 02 GT had a bad pass side valve cover. I was sold a replacement valve cover, but it wasn't from a mustang, I believe it was from a Grand Marquee? Either way, I deleted the EGR Valve, and had the vacuum lines ran differently from the guy that did my engine swap. Now I'm blowing white smoke out of the tail pipes and I think it's because I do not have a PCV valve and just an air filter breather cap rather than an oil cap.
I need to know where the Vacuum line is supposed to go from the back of the plenum, and the front, bottom right of the plenum (I believe this was the PCV valve hose line). The way it is now, the front bottom vac line is blocked off, and the rear vac line splits into 3 (1 going to the old PCV valve area, another going to some sort of valve (can't remember what it's called, hangs by the firewall... on the tip of my tongue), and I don't know where the third goes. Any help would be much appreciated.
Darkcrime is offline
Old 08-23-2013, 06:58 PM
White smoke is coolant or water.
If it was burning oil it would be blue.
Old 08-23-2013, 08:01 PM
Darkcrime
Darkcrime's Avatar
I've heard if the PCV valve isn't working or not there, you can have white smoke. I'll research it some more to find out why that is the case.
Anyway, I figured out the correct pattern I needed so I'm all set.
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
TCStangerv6
10-11-2015 05:57 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Got a weird one - Vacuum lines
