accufab 84.5mm throttlebody and kn intake review.
Old 08-26-2013, 10:00 PM
Shane780
Shane780's Avatar
Default accufab 84.5mm throttlebody and kn intake review.
Both of these products fit great, and had a slight power increase along with a 2 mpg city increase, no noticeable increase on the highway. The Kn Typhoon intake has an aluminum tube which gets quite hot at idle, and increases intake air temperature by about 10 degrees c, but once the vehicle is in motion it has the same air intake temperature, as external air temperature. I did not notice a power increase, but my wife noticed it over the course of a week, she asked what I did to the car and said it felt more "snappy" and she liked it. There is a noticeable sound difference and it eliminates the noise tube, does not sound louder but has a deeper growl to it. Water does not leak into the intake it has an enclosed box which utilized the factory scoop. The engine cover, covers the throttle body and the hose couplers for a nice looking fit.
Shane780 is offline
Old 08-29-2013, 10:02 PM
Shane780
Shane780's Avatar
Default Throttlebody alone
Ran the Car with just the Accufab throttlebody and the stock airbox with a kn panel filter. Car seems more responsive then it did with the KN intake. And idle temperatures are much cooler. 37c today and I was getting some bad heat soak today was running 20c above external temperature. However once in motion it was only 7c above external. I had to use a step down hose from throttlebody to stock intake. I used a specter 4" to 3.5 " rubber coupler, and had to slice off the factory rubber coupler off the box assembly. Made for a great fit.
Speaking to the folks at Accufab they claim the throttlebody provides an increase of 14ftlbs of torque, but no peak horsepower gains. Also that the Ford unit is identical, and does not require a calibration you can just bolt it on. Speaking to the folks at Ford they claim their throttlebody provides an
increase in power in the midrange.
Shane780 is offline
Old 08-29-2013, 10:17 PM
VistaBlueFrank68
VistaBlueFrank68's Avatar
For engine heat, try Royal Purple "ICE". Two in the radiator and my 2013
ran cooler all day and night for 14 passes at the Strip. A cooler engine is a
stronger engine. Can't hurt to try it once, I didn't have to raise my hood to cool.
Now for the 84.5, how will that react when coupled with L/T's and Cat-X? PnC the heads? The 84.5 and 90 need a fast flow to be of use. I plan to do the ladder two but don't want to spend $5-600 on a T/B that will only get me a 2 mpg. I see that number every time a mod doesn't deliver a kick.
VistaBlueFrank68 is offline
Old 08-30-2013, 06:36 PM
Shane780
Shane780's Avatar
Default price
I paid 490 for mine shipped.
I tried driving with just the stock throttlebody and I did notice a loss, slight but not much. I would agree It probably gives a slight increase in torque and responsiveness. But its not a supercharger. 14ft lbs of torque is like a 4% increase if that.
At 100k I would like to have a Paxton supercharger installed and have decided to hold off from further mods other then tires and rims.
Shane780 is offline
Old 09-04-2013, 11:28 AM
Nocturnal'14
Nocturnal'14's Avatar
Originally Posted by Shane780
Also that the Ford unit is identical, and does not require a calibration you can just bolt it on. Speaking to the folks at Ford they claim their throttlebody provides an increase in power in the midrange.
Whats teh "Ford UNit" TB you speak of? The stock one!? Cause I cant find a FORD TB info anywhere.
Nocturnal'14 is offline
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: accufab 84.5mm throttlebody and kn intake review.
