New LCA's - Did you reuse your bolts?
Old 08-30-2013, 08:11 AM
6508ragtops
6508ragtops's Avatar
Default New LCA's - Did you reuse your bolts?
Installing new LCA's next week. Ford recommends changing the bolts and nuts and I was quoted $78 for the set at the parts department - ouch. Depending on how hard these are to get unmounted, wouldn't loctite and reuse do the trick?
i have read that many of this forum members have changed out LCA's. Most threads I researched don't mention the hardware.
So what did you do?
6508ragtops is offline
Old 08-30-2013, 03:34 PM
CPTCO
CPTCO's Avatar
I reused mine. A little loctite and no problems this far.
CPTCO is offline
Old 08-30-2013, 04:39 PM
CMcNam
CMcNam's Avatar
The relocation brackets I used came with new bolts for the rear part of the LCA, but I reused the front bolts. Loctite is awesome.
CMcNam is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
UrS4
09-30-2015 10:13 AM
2poor4u2
09-26-2015 11:08 AM
maestro1024
09-21-2015 02:40 PM
Quick Reply: New LCA's - Did you reuse your bolts?
