Sponsored by: DashLynx
Should I be mad at this trolley jack?
Old 09-07-2013, 09:47 AM
steev
steev's Avatar
Default Should I be mad at this trolley jack?
I bought a cheap trolley jack from Sears at the start of the year probably got 8 lifts out of it. I went to use it today to lift up my car high enough to get a stand under it and nope. I pumped it up, it slowly slipped down. Pumped it back up, nearly high enough to slip the stand in place, slipped back down.
Should I even bother taking this to Sears and try to get it replaced when I feel like the same model will mess up on me again?
Obviously, I should pay more for a decent floor jack, but what would you recommend for around $100. I'm not using it all the time, perhaps once every so often for routine maintenance.
Cheers
steev is offline
Old 09-07-2013, 09:58 AM
Murgatroy
Murgatroy's Avatar
Stupid question, but you have the release valve tight on it, right?
I have been using a Torin Black Jack for about fifteen years now, I bought it for $15? at Walmart. It has been steadfast and has been used a couple hundred times with no issues.
Murgatroy is offline
Old 09-07-2013, 10:03 AM
steev
steev's Avatar
Yeah, always, I'm paranoid about the car falling on me, so try to get the valve tight.
steev is offline
Old 09-08-2013, 09:38 PM
tinman
tinman's Avatar
I'd go to Harbor Freight and get one.
It sure won't be $150.
I got one of those types close to 25 years ago and it still works great.
Get a steel one, not the aluminum one.......
tinman is offline
mtgldr
02-03-2024 09:00 PM
10-01-2015 05:13 PM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
tj@steeda
Steeda Autosports
09-17-2015 07:57 PM
Quick Reply: Should I be mad at this trolley jack?
