CJ Pony Parts We carry Ford Mustang parts for every Mustang built from 1964 to present. CJ's has everything you need to restore your Mustang or make it the performance & aftermarket styling machine you always dreamed of!
Whiteline Transmission Mount Insert 2011-2014 GT/2012-2013 Boss 302
Old 09-10-2013, 12:02 PM
Steve@CJPP
Former Sponsor
Steve@CJPP's Avatar
Default Whiteline Transmission Mount Insert 2011-2014 GT/2012-2013 Boss 302
Whiteline Transmission Mount Insert for 2011, 2012, 2013 and 2014 Mustang GTs with a Manual Transmission and all 2012-2013 Boss 302 Mustangs.
Ford really stepped up to the plate and hit a home run with the 2011-2014 5.0L Coyote powered Mustangs, but fell short when they designed the transmission mount for the 6-speed manual transmission. This is where Whiteline steps in and offers their Transmission Mount Insert for 2011, 2012, 2013 and 2014 Mustang GTs with a Manual Transmission and all 2012-2013 Boss 302 Mustangs, as a direct replacement and performance upgrade over the stock insert bushing.
The factory transmission mount has extreme voiding that allows for excessive and dangerous transmission movement which causes misalignment of the linkage mechanism. When that happens the end results are in the form of missed-shifts and binding under aggressive shifting or heavy-cornering. Whiteline has designed this simple, yet effective insert as a direct replacement for your factory transmission mount that fills those voids and improves overall shift engagement during spirited driving, which results in more precise shifts when they count the most!
If you're tired of grinding gears and missing those critical high RPM shifts, this Transmission Mount Insert from Whiteline should be the go to choice for your 2011-2014 GT or 2012-2013 Boss 302!
*Fits factory 6-speed transmission mounts only.
*The insert bushing comes in black.
Take your shifting to the next level with one of the many different 2011-2014 Short Throw Shifters and Accessories offered by CJ Pony Parts!
KDT928 Mustang Whiteline Transmission Mount Insert 2011-2014 GT/2012-2013 Boss 302 | CJ Pony Parts
Steve@CJPP is offline
jwog666
12-27-2021 08:09 PM
PaulH2
20
01-31-2016 09:48 AM
b8checker
09-30-2015 07:11 AM
wraith777
09-28-2015 10:49 AM
tj@steeda
Steeda Autosports
09-16-2015 07:53 PM
Quick Reply: Whiteline Transmission Mount Insert 2011-2014 GT/2012-2013 Boss 302
