wiring a cooling fan to amp ?
Old 09-20-2013, 04:53 AM
panther15
panther15's Avatar
Default wiring a cooling fan to amp ?
Has anyone used a cooling fan for their amp? If so, how did you wire it up? Can you just connect the positive on the fan to the positive on the amp and the same with the ground? Will the fan turn on and off with the amp as well?
panther15 is offline
Old 09-20-2013, 06:44 AM
vixr
vixr's Avatar
there are a few considerations, is the amp 12VDC? is the fan 12VDC? Is the amp switched on by the stereo? Will the fan cause noise on the signals? (you may hear a buzz or hum through the speakers)
vixr is offline
Old 09-20-2013, 07:07 AM
panther15
panther15's Avatar
I assume the amp is 12V, but not positive. Here is the link for the amp I'm getting: http://www.ebay.com/itm/NEW-SOUNDSTORM-SSL-EV22000-2000W-2-CH-CAR-AUDIO-AMPLIFIER-AMP-2-CHANNEL-EV2-2000-/390663536302?pt=Car_Amplifiers&hash=item5af55c7eaeand as for the fan, it is 12 volt. Here is the link for the fan I'm getting: http://www.sonicelectronix.com/item_...rpion-TF8.html
Yes the amp will be switched on by the stereo (that's what I'm shooting for anyways). As for the fan causing noise...i hope not. I plan on mounting it on the opposite side of the RCA cables. So not sure what will happen.
Old 09-20-2013, 04:54 PM
TheDullahan
TheDullahan's Avatar
you could always wire the fan up to a temp switch like for a radiator fan and set it to turn on when the amp gets to whatever temp point you want. You could just atache the probe to the heatsinks or the case. Then all you have to do is hook the fan up to any switched 12v source.
TheDullahan is offline
Old 09-20-2013, 06:01 PM
Don't do that. That is an excellent way to get noise into your sound system.
Do take a standard power relay and connect it accordingly.
http://www.r1200gs.info/howto/relay.html
Very simple, very basic, and protects your system from unwanted noise.
Old 10-19-2013, 06:43 AM
ticopowell
ticopowell's Avatar
I hooked 2 up to a truck I had, had one blow and one suck, they were behind the seats of an F-150 that I had. I hooked them up to the negative, and then the turn-on wire from the HU and I never had any buzzing or overheating . might work for you too.
ticopowell is offline
jwog666
12-27-2021 08:09 PM
PaulH2
20
01-31-2016 09:48 AM
Dathan
10-05-2015 05:52 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
09-25-2015 09:06 AM
Quick Reply: wiring a cooling fan to amp ?
