66 mustang eleanor front end help
Old 09-23-2013, 07:12 PM
Zach24
Zach24's Avatar
Default 66 mustang eleanor front end help
Okay so i have a 66 mustang and im doing a eleanor front end do i have to get aftermarket fenders? My front end is not lining up right with them
Zach24 is offline
Old 09-23-2013, 07:44 PM
ajzride
ajzride's Avatar
Where did you the front end from? They are all a little different.
ajzride is offline
Old 09-23-2013, 09:17 PM
Zach24
Zach24's Avatar
Ebay they are good quality paid $600 for upper and lower with shipping just don't know if i have to get the fiberglass fenders i will try to take pictures of what exactly im talking about
Zach24 is offline
Old 09-23-2013, 09:57 PM
ajzride
ajzride's Avatar
Paste a link or a picture of the piece. You need a nose designed specifically for a 65/66, if you bought a unit designed for a 67/68 it will not work.
To my knowledge mine is the only 65/66 that uses a longer hood. Notice how the backside where the headlights mount is square, and not slanted like a 67.
ajzride is offline
Old 09-23-2013, 10:43 PM
Cobra6
Cobra6's Avatar
If you got the correct kit for a '66 you should not have to modify or change the fenders.
Cobra6 is offline
Old 09-24-2013, 12:10 PM
Zach24
Zach24's Avatar
Default Eleanor nose
http://bit.ly/18ndFpk
Zach24 is offline
Old 09-24-2013, 12:15 PM
Zach24
Zach24's Avatar
No the parts i got are for the 66 mustang
https://www.google.com/search?tbm=is...x3YKA51Qe4M%3A
Zach24 is offline
Old 09-24-2013, 12:29 PM
ajzride
ajzride's Avatar
Okay, you have the right part, and you should not need new fenders. What type issues are you having with fitment. Perhaps some pictures of what is not lining up?
My advice would be to loosen all the bolts on the fenders except the very back one, this way you can adjust the fenders wider or narrower to line up as best as possible with the upper nose. Here is a link to where I went about fitting mine up:
http://www.moddedmustangs.com/forums...ml#post4950902
ajzride is offline
Old 09-25-2013, 03:19 PM
Zach24
Zach24's Avatar
im having fitment issues where the original valence would bolt up in the front of the fenders it seems as if the nose is shaped different where it bolts but i will try to loosen the fenders and try fitment, im not sure on how to upload pictures quite yet
Zach24 is offline
Old 09-25-2013, 04:23 PM
ajzride
ajzride's Avatar
Fiberglass is notorious for bad fit, even good fiberglass. Figure the pictures out, someone can show you what to bend/grind/etc to get it working.
ajzride is offline
Quick Reply: 66 mustang eleanor front end help
