theft light stays on
Old 09-23-2013, 08:13 PM
beeker
beeker's Avatar
Default theft light stays on
The theft light on my 99 v6 stays on all the time. It starts and runs ok but the light stays on solid with or without the key in the ignition, running or not.
It is annoying as hell and I'm waiting for something to screw up on it.
any suggestions ?
beeker is offline
Old 09-24-2013, 08:31 AM
stangant
stangant's Avatar
This is a strange problem, if the light is solid it usually means it thinks it is stolen and won't start. Have you tried to do a reset, not sure how much this will help but you could always do the 15 min trick. Normally the light is only on/flashing when parked.
If nothing works you could always take it to a local Ford shop and have them look at/reset your pats.
stangant is offline
Old 09-24-2013, 02:04 PM
beeker
beeker's Avatar
not having much experience with the new edges what is the 15 minute trick - disconnecting the battery for 15 minutes ?
beeker is offline
Old 09-26-2013, 08:30 PM
beeker
beeker's Avatar
Now this is really weird, if I take the CD out of the player and just use the radio the PATS works ( goes off when car is started and flashes with key removed) When I put a CD back in it screws up again ?????
beeker is offline
piotrek53
10-13-2015 06:54 PM
Seanam
10-04-2015 10:15 AM
Beerman309
09-19-2015 01:16 AM
MusicCity615
09-12-2015 07:05 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: theft light stays on
