How do i fix this oil cooler? [video]
Old 09-26-2013, 11:18 PM
bitchinmustang
bitchinmustang's Avatar
Default How do i fix this oil cooler? [video]
I have a 1996 Mustang GT 4.6L V8 which has an oil cooler. The oil cooler is leaking out oil so fast when i turn the car on and i do not know what it takes to fix it. Is it just a rubber gasket/seal? do i need a whole new oil cooler? Here is a video of the leak in action. It starts leaking at 12 seconds. Pictures are attached as well.
Attached Thumbnails How do i fix this oil cooler? [video]-img_0600.jpg   How do i fix this oil cooler? [video]-img_0603.jpg   How do i fix this oil cooler? [video]-img_0604.jpg
bitchinmustang is offline
Old 09-27-2013, 06:18 AM
I wanna say there is a 5/16 " allen head that you can try to tighten up or remove and change the large O ring . If you don't have a large enough allen wrench you can use the head of a bolt and 2 nuts jammed together .
Old 09-27-2013, 06:32 AM
This may just need tightened up , because sometimes if a filter was on too tight when you try to take it off it loosens up that long threaded tube and over time it will leak at the O ring
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
MusicCity615
09-12-2015 07:05 AM
kevsgt
09-09-2015 06:20 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: How do i fix this oil cooler? [video]
