need some input..
Old 09-30-2013, 12:12 PM
Whitestang41791
Whitestang41791's Avatar
Default need some input..
ordered amr wheels little while back and when i put them on, the steering wheel is shaking at highway speeds ( yes i took the litle black thing off of the studs). American muscle has sent me warranty wheels but they are doing the same thing. They have been road forced balanced and seem to check out. suspension shop says everyhing is ok and that the wheels are balanced, what am i missing?
09 gt 52,000 miles
thanks
Whitestang41791 is offline
Old 10-01-2013, 07:52 AM
Nuke
Nuke's Avatar
Is the shaking noticeable only in the steering wheel and not throughout the car? Have you tried another shop? If the retainer clips have been removed and everything checks out on a RoadForce balancer, then I'd have the front suspension looked at by a qualified shop that specializes in front end work.
Nuke is offline
Old 10-01-2013, 08:15 AM
Rudolph Hucker
Rudolph Hucker's Avatar
take em to another store
will be balancing problems..these cars are very sensitive to it.
i had to have mine rebalanced.
oh one other thing i hope your using spiggot rings with ya new wheels..the wont ever sit mm perfect without em.
both of my stangs needed them..without them it was pretty much undrivable
Rudolph Hucker is offline
Old 10-01-2013, 10:35 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
09 gt 52,000 miles
thanks
^ I would agree with this. Take the wheels over to another location and have them rebalanced. The odds are you having issues with 2 sets of brand new wheels, is near impossible.
Can you give us a little more information on the vibration and mods?
-Dan
AMDanBailer is offline
Old 10-01-2013, 10:48 AM
CPTCO
CPTCO's Avatar
Is the shaking more of less noticeable when you are on or off the gas? It does seem odd that you would have the same issue with two sets of wheels. Are they staggered or could you rotate them? Maybe you could isolate the problem then.
This is an odd one though. Maybe rings, possibly a U joint or something.
CPTCO is offline
Old 10-01-2013, 12:09 PM
Whitestang41791
the reason i think it is the rims, is because with these new rims the shaking IMPROVED. the suspension is stock.
Old 10-19-2013, 09:01 PM
runstang22
runstang22's Avatar
Every time Ive ever had that problem its was one of 2 things. The lug nuts weren't tightened enough or the rim was bent because I curb checked it. Hopefully its not the latter.
runstang22 is offline
Old 10-20-2013, 05:42 PM
JCON
JCON's Avatar
I have AMR wheels but bought tires from a different site. Had them mounted and balanced at Firestone, zero issues.
JCON is offline
Old 10-20-2013, 05:58 PM
SpartaPerformance
SpartaPerformance's Avatar
What's the offset on the wheels? What size? If you change offset and increase wheel size should also do a Toe adjustment, you should set Toe In 0.01 degree for every step up in width. Ex. if you go from 235 to a 265 front you should set Toe In 0.03 degrees from factory center.
SpartaPerformance is offline
Old 10-21-2013, 12:34 PM
Whitestang41791
19x 8.5 +30mm offset
245-45-19
i did have an alignment done but not with the spec you mentioned.
Quick Reply: need some input..
