UMI Performance Rear LCA vs Maximum Motorsports Rear LCA (1 poly, 1spherical end)?
Old 10-03-2013, 04:32 PM
kingrukus
kingrukus's Avatar
Default UMI Performance Rear LCA vs Maximum Motorsports Rear LCA (1 poly, 1spherical end)?
I currently have a pair of used UMI Performance Rear Lower Control arms (adjustable length) that I haven't gotten around to install.
http://umiperformance.com/catalog/in...hpb278vvshs9b7
A local deal has come up on Maximum Motorsports MMRLCA-5 Rear Lower Control arms.
Both arms have a poly bushing at the at the chassis end and a spherical bushing at the axle end. However the UMI is also adjustable length.
Should I stick to the UMI's, or move to the Maximum Motorsports?
http://www.maximummotorsports.com/st...roducts_id=518
I am hoping to reduce the side-to-side rear end unsettling movement my car does over bumps.
kingrukus is offline
Old 10-03-2013, 07:04 PM
reldla1996
reldla1996's Avatar
I don't know that there will be a big difference between the two (I favor MM, but...), but neither one will eliminate side to side motion of the rear axle. The rear upper control arms are what control side to side motion in these cars.
reldla1996 is offline
Old 10-04-2013, 08:32 AM
school boy
school boy's Avatar
This pretty much sums it up. I do favor the mm products but either will due.
school boy is offline
Old 10-07-2013, 10:37 AM
Fryguy22
Fryguy22's Avatar
They will help a bit with the side to side movement but not eliminate it. Don't even waste your time on replacing the UCA's they are a horrible band-aid design. Start with your LCA's and aim for either a panhard / torque arm or watt's link setup. If you don't have subframe connectors, do them NOW!
Fryguy22 is offline
Old 10-07-2013, 01:31 PM
uberstang1
Chupacabra
uberstang1's Avatar
Pressing a spherical bushing in the rear end and using a spherical bushing adjustable upper control arm is by far the way to go if if your looking for street/drag strip performance. Panhard/torque arm and watt link setups are for autocrossing and handling and will pale in comparision to a proper 4 link setup as far as a drag performance standpoint.
uberstang1 is offline
JonnyBlazeGT
11-03-2015 01:10 AM
GimpyHSHS
08-29-2015 06:30 PM
bikerdoc
08-25-2015 06:46 AM
WDScott
08-17-2015 06:38 AM
JonnyBlazeGT
08-09-2015 10:19 AM
Quick Reply: UMI Performance Rear LCA vs Maximum Motorsports Rear LCA (1 poly, 1spherical end)?
