2014 GT transmission shot
Old 11-20-2013, 12:22 PM
  #21
jhawkr
jhawkr's Avatar
Sounds like a bad torque converter maybe? My 2014 5.0 Auto has 6600 on it. No problems so far.
jhawkr is offline
Old 11-21-2013, 05:56 PM
  #22
Hunter1660
Hunter1660's Avatar
It's the torque converter...but it's the new self healing kind.....and I wasn't even charged extra for that luxury....so far so good,wife drives it daily...
Hunter1660 is offline
Old 11-22-2013, 01:49 PM
  #23
04mineralgreyGT
04mineralgreyGT's Avatar
Good to hear that the car is OK. I haven't heard many issues with the auto trans.
04mineralgreyGT is offline
Old 11-27-2013, 09:00 AM
  #24
jhawkr
jhawkr's Avatar
Wink
Ah......, the wife! In my case, that would be the problem!
jhawkr is offline
Old 07-02-2014, 01:54 PM
  #25
snogoldi
snogoldi's Avatar
2006 V6 Mustang 46,000 Miles Had to rebuilt my Transmission
FORD "FOUR VERSIONS OF 5R55"
Just as the header states, the Ford 5R55 Transmission can have an N, S or W behind those numbers.
The 5R55 is a rear wheel drive 5-speed that appeared on 1999 and later vehicles.
The 5R55W came out in the 2002 and later Ford Explorer and Ford Ranger models.
The 5R55N appeared in the Jaguar S-Type and Lincoln LS and in 2002 in the Ford Thunderbird. In 2003 the Thunderbird and Lincolns switched to the 5R55S that had the Select Shift (allows drivers to shift like a standard without the clutch).
The 5R55S without the Select Shift is used in the 2005 and later models of the ford Mustang.
Although the 5R55N is very similar to the W or S models, only a few parts are interchangeable.
The common problems we see on these units are the excess wear on the case or valve body.
We receive numerous calls about these where someone has rebuilt the transmission, yet still experiences the same symptoms.
Transmission case premature wear occurs on the Overdrive and Intermediate Servo bores. Apply oil comes up through the servo pin bore and through the hollow pin applying the servo. This requires the the pin to seal in the servo pin bore, as well as the release oil that both servos require. Over time the number of apply and release wears out and the pin no longer can seal properly. The Overdrive servo bore will usually have more wear due to it being used for second and fifth gear. As the servo leaks, which will result in a pressure loss that lacks the pressure to hold either the band completely applied or release it fast enough to prevent the band from being burned up.
These can be repaired without replacing the case. By drilling the servo bores and installing a "cesleeve" to compensate for the wear, eliminates the need to replace the case. The Brass sleeve has proven to be more durable then the aluminum case giving you stability. You don't want to use a "used case" as the possibility of the bores being worn in a used case are more than likely.
The Valve body can also have excessive wear, most often seen on the TCC (torque converter clutch) modulator bore, or main regulator bore.
As in the case situation, the high duty cycle of use wears down the bore reducing clutch and servo pressures.
Although the PCM (power control module) will try and compensate with adaptive strategy, the excess wear will cause gear ratio or slipping codes.
A Valve body repair or Update kit will usually correct these problems.
These are just a couple of most common problems seen on these transmissions and not all these problems may have this problem.
Gear ratio error Codes are very common on these transmissions due to servo pin bore wear occurring at a very low mileage in some cases.
You can have a gear ratio error code without having an electrical code (Solenoid) but unlikely that you will have an electrical circuit code without a gear ratio error code.
Having a proper diagnostic by qualified techs will eliminate the guess work and save you major expenses in the rebuilding of these transmissions.
snogoldi is offline
Old 07-02-2014, 02:35 PM
  #26
Totally irrelevant. The SR55S is a totally different (5-spd) tranny. What they started using in the 2011+ models are 6 speeds (6R model).
Old 07-04-2014, 09:03 AM
  #27
GTC
GTC's Avatar
Man, glad I dropped the 2 grand for 100,000 mile Ford bumper to bumper warranty.
GTC is offline
Old 07-06-2014, 12:32 PM
  #28
PeteInFlorida
PeteInFlorida's Avatar
Good luck with your car Hunter. I feet the same way as you do about my 14 Mustang GT.
PeteInFlorida is offline
Old 07-07-2014, 06:36 PM
  #29
Hunter1660
Hunter1660's Avatar
Car has a lil over 20,000 miles on it now and no problem with torque converter...over all it's a great car....only issue with it now,and it's done it all along is a knocking at 1000 rpm's...sounds like a rod knocking but I know it's not.It would have came apart by now.
Old 07-13-2014, 10:33 AM
  #30
tenfifteen
tenfifteen's Avatar
Man, that's bad. I'd heard about the issues with the 82 of course, but never with the auto. We have the "auto" in my wife's '12 Focus and it was rebuilt at 50k, but it's a true DCT, not a wet-clutch auto like this one. Very surprising.
tenfifteen is offline
jerrytubes
10-23-2015 12:11 PM
mdg
10-01-2015 07:04 AM
wraith777
09-28-2015 10:49 AM
folivier
09-26-2015 02:28 PM
Quick Reply: 2014 GT transmission shot
