low reading on dip
Old 10-05-2013, 10:52 AM
amaNIN
amaNIN's Avatar
Default low reading on dip
Has anybody ever gotten a low reading on the dipstick after putting 5.1 quarts of oil in an S197 v6 crankcase? The capacity is 5 quarts and I am still getting a low reading. The level is maybe a half inch below the top hole on the dip. Just wondering if this is unusual. My 1.9L Saturn was 4 quarts every change, so this was my first change with the pony so I am just wondering...:icon_qu estion:
amaNIN is offline
Old 10-05-2013, 01:28 PM
Nuke
Nuke's Avatar
First, as long as you're between the 2 holes on the dipstick, your level is fine. Second, if you've added over 5 quarts and you still believe it's reading low, then I'd have to ask if you're using the OE Motorcraft filter or some other, possibly oversized, filter. Either way, I wouldn't sweat being in between the 2 holes with 5.1 quarts.
Nuke is offline
Old 10-06-2013, 09:13 AM
amaNIN
amaNIN's Avatar
Ahhh that's it! The filter I replaced was almost twice as big as the old one. I was like, "WHAAAAAA!" when I first compared the two. The thread looked the same and there was room for it so idk. That explains the low reading. More oil will go into the filter. Thanx dude! I never would have figured that out.I only spent 6 bucks on the filter and I think it was a toughguard but not sure. doesn't really matter what kind of filter u get, does it?
amaNIN is offline
Old 10-06-2013, 02:25 PM
Siber Express
Siber Express's Avatar
I run Motorcraft on mine. You must have bought a PH8A Fram, I can't remember if it is 1/4 of a quart or 1/2 quart over the stock filter.
BTW that is the same oil filter my 4.0 in my old Explorer ran.
Siber Express is offline
Old 10-06-2013, 06:00 PM
Nuke
Nuke's Avatar
Originally Posted by amaNIN
... Thanx dude!...
No problem. Two heads are better than one.
Nuke is offline
Old 10-06-2013, 07:00 PM
amaNIN
amaNIN's Avatar
Its a Puralator brand filter. And yeah Ive got an explorer engine in my pony. So why do they make larger filters? More filtering space to filter I guess.
amaNIN is offline
Old 10-10-2013, 10:02 AM
2005Redfire6
2005Redfire6's Avatar
Damn, you managed to find a bigger one then the one they already use?!
2005Redfire6 is offline
Old 10-10-2013, 12:02 PM
Nuke
Nuke's Avatar
....doesn't really matter what kind of filter u get, does it?
I used to use Fram filter's a LONNNNNG time ago and to be frank, I wasn't very smart knowing what I know now. Fram filters have a bad reputation (at least the older "rag-in-a-can" all orange filters) although the ToughGuard isn't the worst out there.
The OE Motorcraft filters actually have a very good track record. I use them in my wife's '06 V6 Pony since we change her oil within about 6k-7k miles but I use Amsoil eA filters and Mobil1 filters on my Stang and the SUV since I tend to go 8k-12k miles between oil changes. The Motorcraft filter just doesn't seem to hang in there with the others I mentioned over those longer mileages.
Nuke is offline
Old 10-13-2013, 12:01 PM
tx_zstang
tx_zstang's Avatar
+1. I use the 820S motorcraft filter; they are better and lower in price than any fram or other brand (walmart sells them locally for under $4).
Normally, a v6 will take around 4.5 quarts with filter. I've never put over 5 quarts into one of my v6's. Make sure the dipstick is all the way down of course.
tx_zstang is offline
Omgitsa88Stang
10-05-2015 07:33 AM
GimpyHSHS
09-18-2015 12:27 PM
dalefrancis88
09-11-2015 07:15 AM
zanemoseley
09-06-2015 12:58 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: low reading on dip
