Shifter suck in Reverse
Old 10-08-2013, 11:26 AM
goalieart
goalieart's Avatar
Default Shifter suck in Reverse
I am in need of some help. My car drives fine but currently it will only go in reverse.
The other day tried to make a U turn on a narrow street, street was too narrow, so before i touched the curb, I stopped, put the car in reverse to line up with the street, then went to go into first gear to get going where i needed...problem is that the shifter would not come out of reverse.
I was not in a hurry, I didn't force it into reverse, I didn't hear or feel anything unusual...it is just stuck.
The clutch is fine I can feel the clutch allowing it to come out, but something is holding it in reverse in the transmission.
Any ideas as to what it is or how i can fix this with out spending a small fortune?
goalieart is offline
Old 10-08-2013, 12:21 PM
edwin108
edwin108's Avatar
Is it still stuck in reverse with the engine off?
edwin108 is offline
Old 10-08-2013, 12:34 PM
goalieart
goalieart's Avatar
Yeah....engine on or engine off...doesn't matter. I press the clutch in and try to get it out of reverse and it will not come out at all
Old 10-08-2013, 04:14 PM
AzPete
AzPete's Avatar
Sounds to me like a shifter issue. Does it drive ok in reverse....nothing feels wrong there¿
AzPete is offline
Old 10-08-2013, 08:52 PM
BMWiduch
BMWiduch's Avatar
check your bearings and gears most likely one has stripped. If not, check your transmission connecting to the engine (pressure plate, make sure your clutch plate is fully intact)
BMWiduch is offline
Old 11-19-2013, 06:41 PM
cjhstang
cjhstang's Avatar
Has this been resolved? Mine just did this when i parked at work...
cjhstang is offline
Old 11-19-2013, 08:33 PM
Thatsweetstang
Thatsweetstang's Avatar
Wow never even that could happen, you'd think with the car off it would come out. If it was me I would assume something broke or slipped just a little to get something stuck and I would force the stick out. Just because our trans are cheap and luckily you can get another fairly cheap if you break it. But that's would I would do to my own car. I'm just gonna sit back and see what other people have to say to fix this problem
Thatsweetstang is offline
Old 11-19-2013, 11:46 PM
goalieart
goalieart's Avatar
My buddy is a Ford tech, he says I most likely need a new tranny. Looking into it more. Can't afford a new tranny right now. Thank god I have a sport trac as well
Old 11-20-2013, 12:38 AM
cjhstang
cjhstang's Avatar
Got ya... I got lucky and was parked against a rock behind my tires. Was able to reverse and bounce off the rock and as I was moving forward played with the shifter and clutch. Finally got it out of reverse that way without breaking anything. Put it in reverse a few times afterwards and no problems... Weird...
cjhstang is offline
Old 12-07-2013, 10:14 PM
Prpfire3
Prpfire3's Avatar
Sorry to tell ya it needs rebuilt my was doing the same i figured out that if i was to let out on clutch kinda quick and held pressure on shifter it would come out or hold pressure on shifter and go in rev and tap the gas it would come out but i just got myn outta trans shop yesterday for this reason of urs
Prpfire3 is offline
Quick Reply: Shifter suck in Reverse
