3G alternator in a 1968 coupe.
Old 10-13-2013, 08:05 PM
wvroughneck
wvroughneck's Avatar
Default 3G alternator in a 1968 coupe.
I've searched the forums and havent seen anything mentioned about the original voltage regulator. Is it necessary with the new alternator and if so which wires go from the new alternator to the wires from the old voltage regulator?
wvroughneck is offline
Old 10-14-2013, 09:33 AM
Starfury
Starfury's Avatar
No, a 3G is internally regulated and does not require the external regulator. Can't tell you which wires go where, though. Usually if you google "3G alternator conversion" you come up with something. The factory service manual wiring diagrams would be helpful here.
Starfury is offline
Old 10-14-2013, 02:15 PM
jlg2002
jlg2002's Avatar
Starfury is right on. To prevent confusion, sometime in the future you may want to remove the Vreg from the car - it is not necessary once the 1 wire system is put in. Also if you have upgraded the alternator output to more amperage, it's a good idea to run a second wire (2 Ga or larger) from the alt B+ term to the battery side of the starter relay terminal. The factory wire is not designed to carry the extra electrical load.
jlg2002 is offline
Old 10-14-2013, 04:28 PM
wvroughneck
Thank you for your help.
Old 10-14-2013, 07:29 PM
gothand
gothand's Avatar
Here's a wiring diagram:
http://oldfuelinjection.com/public/a...ALT_wiring.gif
gothand is offline
4cylinderplus2
10-09-2020 07:45 PM
Golfsito
10-06-2015 11:02 AM
MasterLanMan
09-26-2015 10:03 AM
Wombatnation
09-13-2015 09:16 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: 3G alternator in a 1968 coupe.
