Clutch wont bleed
Old 10-19-2013, 08:58 AM
jcreynolds91
jcreynolds91's Avatar
Default Clutch wont bleed
So last night I replaced my clutch line with the SR braided steel one. Got everything situated and proceeded to pump the clutch per instructions I've seen on the Internet. After a minimum of 100 pumps the clutch didn't feel different nor was the fluid level different. I then had my girlfriend pump the clutch so I could watch the fluid, and I could watch it go up and down in the reservoir but not just go down. So next course of action, let it sit over night. Still nothing this morning. I've been super slowly pumping the clutch about 10 times an hour now, waiting to see if theres any results. Slightly firmer thus far, but I'm not feeling to optimistic. Does anyone have any advice they can throw my way?
jcreynolds91 is offline
Old 10-19-2013, 12:10 PM
torinalth
torinalth's Avatar
Granted I don't have experience with the current gen clutch (my 02 was cable not hydro) but for any hydrolic clutch, you need to open the bleeder valve to allow the fluid and air to escape the line. From what you typed you are not doing this. The process is just like bleeding the brakes. put clutch to the floor, open valve, fluid/air comes out, close valve, let clutch pedal up, check fluid level in res, repeat till happy.
But since I dont have a current gen GT, I cant tell you were the bleeder valve is
torinalth is offline
Old 10-19-2013, 01:15 PM
edwin108
edwin108's Avatar
Try parking on an incline or jacking up the front end and pumping the clutch pedal.
edwin108 is offline
Old 10-19-2013, 02:15 PM
dlazrael
dlazrael's Avatar
There are no bleeder valves. When I did my clutch I ended up 500+ pumps, and even then as I drove, it scared the **** out of me. I tried to shift into 5th from 4th and it wouldnt grab enabling the 4-5 shift (but it released just fine), thankfully i was able to coast to the shoulder, another 100 pumps and it was good...
HOWEVER,
The approved method is with a vacuum pump; http://www.allfordmustangs.com/forum...25-post86.html
dlazrael is offline
Old 10-19-2013, 07:40 PM
CMcNam
CMcNam's Avatar
It's a self-bleeding clutch, don't need to worry about the valve. It takes FOREVER though. After I replaced my clutch and the line, I pumped the pedal until I couldn't any more (my leg was seizing up) and it started to come back. It takes a lot longer than you would think. After I was able to drive it around for a few days everything was back to normal.
CMcNam is offline
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: Clutch wont bleed
