4.6 gt 55k seems like it's loosing power
Old 10-20-2013, 04:02 PM
I8urGM
I8urGM's Avatar
Default 4.6 gt 55k seems like it's loosing power
I have an 03 gt. Seems like it's running slower, a sec slower in the 1/8. No engine light, no stalling. No noticeable issues. Has anyone had this issue or have an idea what it might be?
I8urGM is offline
Old 10-20-2013, 04:16 PM
uberstang1
Chupacabra
uberstang1's Avatar
Run a compression check and see what you have
uberstang1 is offline
Old 10-23-2013, 06:01 PM
WJL
WJL's Avatar
Don't forget the simple stuff, did you get fuel from a different place how long has it been since the fuel filter and or air filters have been changed, it may surprise you how much performance lost you can get with dirty/old filters maybe even check the spark plugs
WJL is offline
Old 10-24-2013, 10:01 AM
I8urGM
I8urGM's Avatar
Well two months ago i changed my spark plugs with motorcraft plugs, same day i changed the fuel filter. I also changed the air filter for a bbk filter. Ever since then the car struggles to start and doesnt run the same.
I8urGM is offline
Old 10-24-2013, 06:41 PM
WJL
WJL's Avatar
i would just start with the process of elimination, take the air filter off, go for a ride see if there is any difference, you can put a fuel pressure gauge in (after the filter) and measure the PSI to make sure there are no concern with a clogged filter or fuel pump issue. Pull the plugs and inspect them (could be cracked), make sure the COP are on all the way. Good luck
WJL is offline
Old 10-24-2013, 08:47 PM
I8urGM
I8urGM's Avatar
Thanks guys I'm going to try that this weekend. Hopefully it wakes it back up.
I8urGM is offline
Old 10-24-2013, 09:04 PM
kzonts
kzonts's Avatar
Not trying to insult you, but did you install the fuel filter in the proper direction? Just trying to help.
kzonts is offline
Old 10-24-2013, 09:15 PM
I8urGM
I8urGM's Avatar
I hope so lol.
I8urGM is offline
Old 03-15-2014, 10:38 PM
suprafish
suprafish's Avatar
Cheak your plugs. May be junk plugs. U pay for what ya get with plugs
suprafish is offline
Old 03-16-2014, 06:36 PM
Soldier GT
Soldier GT's Avatar
Hey man good info but this is like a 5 mth old post! Hopefully the OP took care of it by now.
Soldier GT is offline
Quick Reply: 4.6 gt 55k seems like it's loosing power
