Electronic ignition help
Old 10-24-2013, 04:47 AM
grahamdiss
grahamdiss's Avatar
Default Electronic ignition help
Hi Guys
I'm sure you have seen this topic many times and I've read lots, which has probably confused me. The car is a 65 289 and I fitted an accuspark electronic ignition (in distributor type) as per the instructions for the ballast resistor (attached) the car would fire but not run, points back on and it's fine. My problem is that there is a small unit to the right of the coil in the pictures attached which I assume is a ballast resistor, I cant think what else it could be. Can I just bypass this and wire up normally or is the wire from the ignition also a resistive wire? I wouldn't think there would be two types of resistance in he circuit. Coil is a Magfire 40Kv so I assume that can take 12v direct and not through the ballast.
Pics attached, I cant trace the grey wire and it doesn't correspond to the wiring diagrams I have but that should be fine with a full 12v.
Any help would be appreciated.
Thanks
Graham
Attached Thumbnails Electronic ignition help-roodepoort-20131020-00142.jpg   Electronic ignition help-roodepoort-20131020-00143.jpg
File Type: pdf
File Type: pdf
grahamdiss is offline
Old 10-24-2013, 02:37 PM
clowe1965
clowe1965's Avatar
I had to wire up my pertronix hei unit to a direct 12v source so I imagine that is the same. Ensure you are getting 12V at the ignition hookup then fire it up.
clowe1965 is offline
Old 10-24-2013, 02:59 PM
jlg2002
jlg2002's Avatar
As it's wired it should work. However, not if the ballast resistor on the side not attached to the coil doesn't have battery voltage on it with the ign key in run (will require a DVM to answer). If it is less than battery voltage that may be a problem since you may be current limiting the circuit current/voltage twice. The ballast resistor may also be bad (open most likely)
Any coil can withstand the direct battery voltage for some period -it will just over heat the coil leading to thermal failure. the coils that are designed for higher voltage just have better thermal aspects or lower failure failure consequences.
jlg2002 is offline
mrtrodonet
09-19-2020 03:12 PM
bradleyb
11-27-2015 07:50 PM
piotrek53
10-13-2015 06:54 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: Electronic ignition help
