Might be getting a 02 GT... What do you think?
Old 10-27-2013, 10:17 AM
amorgan93
amorgan93's Avatar
Default Might be getting a 02 GT... What do you think?
So i just sold my Subaru forester, and am looking for a Mustang GT for under $5500. I went to look at an 02 GT yesterday with a list of mods. I cant find the ad or i would post the pics.
-Aeromotive 1000 fuel pump
-aeromotive fuel pressure regulator
-Aftermarket fuel rails with braided steel lines
-Sumped fuel tank with braided lines from engine to tank.
-subframe conenctors
-tubular k-member
-Centerforce stage 2 clutch kit
-T3650 with tremec upgrade kit and Black nitrated gears
-innovative AFR gauge and wideband
-Sniper tuned for 89 octane
-3.55 gears and corrected speedo
-176k on body, motor and trans rebuild 30k ago.
-fully adjustable short shifter
-Black leather interior in great condition
The engine is a bit questionable, its pretty noisy it sounds loose/rattling when revving, but doesn't sound like a rod bearing or valves, its an odd rattling sound. The car felt great driving, but when sitting still, revving the engine between 1700-3000 rpm the car vibrates and shakes. The owner said it had poly motor mounts and stock transmission mount. When revving the engine, it doesn't move or shake 1 mm under the hood, almost if it has solid mounts.
The car use to have a built 5.4 in it, and put down 450whp. The owner had pictures to prove everything. He said he rebuilt the 4.6 himself before putting it back into the car, and that it was blueprinted.
The transmission in the car shifts GREAT and feels very strong. It took several flat-foot shifts without grinding or anything. The clutch grabs great, the car has 10.5" wide wheels with Nitto tires in the rear, and it easily spun the tires rolling 15mph in 1st gear. Overall the car was nice cruising, was smooth other than the bit of extra noise from the huge fuel pump. The body was almost perfect. The ONLY concern i have is the engine. Just wanted Others opinion. The price of the car is $5000. Thanks!
amorgan93 is offline
Old 10-27-2013, 12:44 PM
kast1376
kast1376's Avatar
I would pass just based on the issues you mentioned with the motor. If there is indeed some sort of issue, it will get expensive quick.
kast1376 is offline
Old 10-27-2013, 02:55 PM
uberstang1
Chupacabra
uberstang1's Avatar
Probably needs a motor, massive fuel pump for a N/A car.
uberstang1 is offline
Old 12-01-2013, 01:48 PM
Jeffk
Jeffk's Avatar
Location: Thomasville, NC Where we beat headers into submission!!
Hmm... is this car near Charlotte, NC by chance? I had a friend look at that car for me and he expressed the same concerns. The owner had a 32V Navigator motor in the car at one point planning on going with twins but changed his mind which is why it has the massive fuel system.
Jeffk is offline
Old 12-01-2013, 02:04 PM
Civic4doorsleeper
Civic4doorsleeper's Avatar
Was your Forester Turbo?
Civic4doorsleeper is offline
Old 12-01-2013, 05:40 PM
Soldier GT
Soldier GT's Avatar
I would steer away from that one. Anytime a engine makes a noise should mot def be some kind of warning. Maybe look at a earlier model new edge (99-01).
Soldier GT is offline
Old 12-01-2013, 09:35 PM
tadpole1969
tadpole1969's Avatar
does it do it worse when u put it in drive and hold the break try this if so itll be motor mounts i have a 2001 gt that had a same issue 2 motor mounts later and new ignition coils all is well so if i were you i would get them to let you take it to a local garge and have it looked over if its mounts your looking at 535.00 thats labor plus parts motor mounts are 100.00 a peice for good mounts
tadpole1969 is offline
Old 12-01-2013, 09:36 PM
tadpole1969
DIY Price 210.00 and alot of swearing lol
Old 12-02-2013, 01:02 PM
amorgan93
amorgan93's Avatar
Yep it was a turbo, and faster than a 00 cobra. I regret selling it now.
And yep this car is near Charlotte nc.
Old 12-02-2013, 01:59 PM
Civic4doorsleeper
Hell you do that for. Forester XT's are faster then New Edge GTs stock lol
Quick Reply: Might be getting a 02 GT... What do you think?
