Stroke or no stroker 331 block available
Old 10-27-2013, 10:27 AM
mebirkle
mebirkle's Avatar
Default Stroke or no stroker 331 block available
Hello,
I have a 331 block available to me for 1k and I was going to put all my parts sitting on my 302 and just move them over. It's a scat block with Keith black flt top pistons balanced with an aluminum flywheel. I have edelbrock performer heads, x cam, trick flow street burner intake, long tubes, that will all move over as far as I am aware.
My concern us the T5 and rear gears. The trans is stock but I have been warned a stock t5 won't hold up. Is that true? What kind of clutch should I be looking at??
Also, I have 373 trac loc gears in the car. Do I need to check the number of splines. Not sure what's in there.
Finally, I need som guesses on what I am upping the horse to. I have 310 to the wheels. What am I hopping up to here? Any other concerns that I should have?
Thanks everyone.
mebirkle is offline
Old 10-27-2013, 10:45 AM
bluebeastsrt
bluebeastsrt's Avatar
The T5 is fine. If you plan on doing a ton of drag racing then upgrade to the aftermarket clutch of your choice? As far as horsepower you wont make a lot more power than your already making with the 331 vs. 302.
bluebeastsrt is offline
Old 10-27-2013, 04:59 PM
Duncan_GT
Duncan_GT's Avatar
There will be a small difference in power between the two motors. The T5 will be fine, its clutch dumps and power shifting they dont get along with
Duncan_GT is offline
Old 10-27-2013, 08:32 PM
reldla1996
reldla1996's Avatar
331 versus 302, 30 cubic inch difference, so about 30 hp and 40 ft lb torque (longer stroke equals more torque). I like how Duncan put the T5, avoid power shifts and you'll probably be okay.
reldla1996 is offline
Old 10-28-2013, 01:41 AM
tinman
tinman's Avatar
A Scat block?
Please school me on this as I've been messing with small block Fords for years and I've never heard of this one.
As a fact, Scat is a company that supply's many stroker cranks, rods etc. to the aftermarket........
tinman is offline
Old 10-28-2013, 07:53 AM
88 orangepeel notch
88 orangepeel notch's Avatar
And as for the gears and axles, what are your intentions with the car, street, strip? If your planning on racing at the track with sticky tires, upgrading axles and carrier are recommended if they haven't been already. Street car with street tires, you'll be fine with the stock 28 spline axles.
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
Matt's 95 Stang
10-05-2015 07:16 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: Stroke or no stroker 331 block available
