do i need a new distributor??
before i tore the engine apart, when the car was running, the car would die every once in a while when it was hot out. i think sometimes when it wasnt even really that hot out. it would cut out and then after 10-20 minutes, it would start back up like nothing ever happened.
i think i read here somebody with similar problems and it was due to some type of component in the distributor (or was it the ignition coil? hmmm) that didnt like the heat. lets say it was due to this distributor component. lets further say you know wtf im talking about. i am going to guess that i wouldnt be able to simply replace the part of the distributor that was failing, right? i would need to replace the whole distributor, yes?
now, i guess i could clean up my old distributor and put it back in and deal with that problem when/if it shows up again. however, the base gasket on the distributor shaft is gone. destroyed. i would need to replace the gasket. i am having trouble finding a replacement though. are these things just not out there?
i was going to simply buy a new distributor until i saw the prices were not cheap, even for remanufactured units. im still not against buying a replacement, i just didnt want to burn cash for no reason.
my goal has shifted from simply just taking the engine apart and putting it back together to wanting it to be a solid dependable ride for my nephew (who wont be driving for a few years anyway)
so, whats my play?
track down a gasket and use the old one?
buy re-furb?
buy new? (if so, which one? please recommend)
feel free to recommend a new ignition coil while youre at it just in case.
so, whats my play?
buy re-furb?
Keep your dizzy, replace the …… um… now I can't remember the name of it. It bolts to the side of your distributor, 2 special little bolts that they make a special little wrench for. I just replaced mine in spring, same symptoms as you. You can actually have your old one tested to be sure. I cant believe I can't remember the name of this.
EDIT: Found it, Ignition Control Module, ( ICM )
http://easyautodiagnostics.com/ford_ignition_module/distributor_mounted_module_1.php
Keep your dizzy, replace the …… um… now I can't remember the name of it. It bolts to the side of your distributor, 2 special little bolts that they make a special little wrench for. I just replaced mine in spring, same symptoms as you. You can actually have your old one tested to be sure. I can't believe I can't remember the name of this.
how much did it cost to replace?
and, this would mean i need a gasket. any ideas on that?
Its called the pip or otherwise Profile ignition pickup. You can replace it but the distributor needs to be disassembled to get to it.
http://www.autozone.com/autozone/par...er=184572_0_0_
Also the tfi short for thick film insulator (ignition control module) can cause this as well. It gets hot and causes bucking missing and stalling then when it cools it runs fine
http://www.autozone.com/autozone/par...8646_300759_0_
Ignition coils also do not like heat, when they start to go bad they will cause severe miss .
looks like im in the market for a new distributor
anybody want to lay some suggestions on me?
