Rear Main Oile Seal Leak
Old 11-15-2013, 09:17 AM
Steve@Tasca
Former Sponsor
Steve@Tasca's Avatar
Originally Posted by waltrobak
You know I am not sure at this point. I did it about a year ago, but I do not remember there being two parts. I know that I only ordered the seal and I remember pressing the seal into the plate, but I do not remember any other part. Does the slinger get pressed in like the seal? I am confused by the diagram, because if I remember the seal pressed in from the outside or back of the plate inward. The diagram looks like the seal gets pressed from the inside toward the back with the slinger between the seal and the plate??? After I pressed the seal into the plate and installed the plate I do not remember adding anything else, in fact when I pulled it apart I don't remember there being anything but the seal present. I am a bit confused.
The seal is pressed into the back of the block, the slinger is pressed in to the rear engine plate so if you only replaced the piece in the rear engine plate then you're still using the old rear main seal.
Steve@Tasca is offline
Old 11-15-2013, 09:12 PM
71_340
71_340's Avatar
Slinger should just be a thin flat metal disc, it's purpose is to deflect most of the oil away from the actual seal. That's the basic design of it.
I only replaced a 4.6L seal one time about 10 years ago on a Crown Vic; at 230K miles it also needed a crank sleeve which fixed the leak. By the way, no seal will stop leaking after a while (unless maybe a rope type seal). If it leaks after installation it will only get worst. Did you replace the gasket for the seal retainer?
71_340 is offline
Old 11-16-2013, 07:56 AM
Steve@Tasca
Former Sponsor
Should be by definition but not on the mod motors. That's why I said "slinger" is a poor description and actually in some catalog listings it's called a baffle but either way it is actually a seal.
Here's the rear main seal and part number,
And this is the slinger/baffle,
Old 11-17-2013, 08:06 PM
waltrobak
waltrobak's Avatar
Well like I said it has been about a year since I installed the seal and I know that I did replace the seal because it looked the same as the old one. I did only order one part, so I starting to think that I installed the new seal, but did not install a new slinger. After all this work I am not so happy right now! If the slinger is not installed what is the worst case, the oil will just slightly drip out as it is, or will it start to poor out when the RPM's are up and the pressure is high?
waltrobak is offline
Old 11-18-2013, 08:38 AM
Steve@Tasca
Former Sponsor
Kind of hard to say what will happen but the leak isn't going to get any better so it's probably best to just buckle down and fix it before it does get worse.
Trust me, I know how frustrating it is to have to do all that work again.
-Steve
Urambo Tauro
09-07-2015 12:47 PM
Itzjoe
08-26-2015 08:15 PM
jesse1125
AmericanMuscle.com
08-26-2015 02:34 PM
Hogquad
08-23-2015 05:26 AM
91StangOwner
08-20-2015 11:34 PM
Quick Reply: Rear Main Oile Seal Leak
