IAT Wiring
Old 11-14-2013, 07:07 PM
71_340
71_340's Avatar
Default IAT Wiring
I just bought an 02 GT and I am in the process of correcting/repairing all the neglect my car suffered from the POs. I just got done replacing the heater core (what a chore) and while I had the engine warming up decided to check for fault codes and have a pending P0113, indicating an IAT problem.
I checked and where the IAT should be there is a plug (usually used to cap a fitting during storage), to top it off somebody cut the connector and just push the two wires out of sight.
My question is if I can fins a connector that will fit on a new IAT sensor does it matter which wire goes where? I have a gray wire and a gray/red stripe wire. Before anybody asks....I have the 4-wire MAF connector.
Thanks!
71_340 is offline
Old 11-15-2013, 11:27 AM
Stevo86
Stevo86's Avatar
Ford is super good about using standardized wire colors for their cars as well as standardized plugs. Just go to your local salvage yard and clip the connector off of another vehicle then all you have to do is match the colors.
Stevo86 is offline
Old 11-15-2013, 07:43 PM
CalBoy101
CalBoy101's Avatar
On 2002's the IAT is built into the MAF, although I guess if it was a really early build it could have the separate IAT. Look at your MAF connector, I think if it has 6 pins then it does have the IAT in it.
CalBoy101 is offline
Old 11-15-2013, 08:54 PM
71_340
71_340's Avatar
Looks like I am heading to the junk yard tomorrow, I'll take the new IAT with me to make sure the connector fits.
I do have 4 wires on my MAF.
Thanks for the replies.
71_340 is offline
Old 11-17-2013, 11:49 PM
71_340
71_340's Avatar
Found a IAC sensor with plug and a short length of wire at the salvage yard........no more codes!
71_340 is offline
Old 11-18-2013, 12:42 PM
CalBoy101
CalBoy101's Avatar
Way cool, nice work.
I can't believe somebody cut off the old one and tried to hide the wires, what a d***.
Old 11-19-2013, 08:12 AM
71_340
71_340's Avatar
I am finding all kinds of neglect on this car as I go through it, I guess the last owner didn't have the funds to properly maintain the car. I am slowly getting things sorted out.
The latest repair was to replace both valve cover gasket; that was almost as bad as a pain in the .... as replacing the heater core.
71_340 is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: IAT Wiring
