90 5.0 cranks but no fire
Old 11-18-2013, 10:42 AM
Sally91
Sally91's Avatar
Default 90 5.0 cranks but no fire
Got a 90 5.0 that will crank over but not fire, I have fuel and the icm tests good. But I'm still not getting spark, tested for power at each pin on the module and coil everything has power as it should. I don't know what else to check
Sally91 is offline
Old 11-18-2013, 04:14 PM
88 orangepeel notch
88 orangepeel notch's Avatar
Took me awhile but I found this that helped me out.
http://sbftech.com/index.php/topic,5...1.html#msg6501
Old 11-18-2013, 06:00 PM
SeanG91
SeanG91's Avatar
Bad PIP sensor in distributor. Always had problems with it.
SeanG91 is offline
Old 11-19-2013, 08:46 AM
Sally91
Sally91's Avatar
Are they changable on these distributors or does the whole thing have to be replaced?
Sally91 is offline
Old 11-19-2013, 09:04 AM
You can change the PIP but the entire distributor needs to be disassembled. I also thought it was your Profile ignition pickup ( pip ) they are known to cause intermittent spark.
For the trouble of replacing it, add about 20 bucks and you can just get a reman dizzy .
Old 11-19-2013, 09:57 PM
SeanG91
SeanG91's Avatar
20 busk for a reman? Where did you get one of those? I'm paying 60 for a reman is I wind up rebuilding mine 20 bucks for the sensor on rock auto. Just a pain to rebuild the dist.
SeanG91 is offline
Old 11-19-2013, 10:08 PM
LOL I meant add about 20 bucks to the cost of a pip and you could get a reman dizzy.
Old 11-20-2013, 10:16 AM
SeanG91
SeanG91's Avatar
Ok makes sense now.
SeanG91 is offline
Old 11-24-2013, 04:34 PM
Sally91
Sally91's Avatar
Put a new distributor complete new cap rotor and module still didn't fix the issue
Sally91 is offline
Old 11-24-2013, 07:01 PM
Rob-1995-Mustang-GT
Rob-1995-Mustang-GT's Avatar
I have the same prob. on my 95 GT. I have a no cold start. I can start it if I work on it until it starts and she runs good after it warms up. However after I let it sit for over 3 hrs I right back to no cold start??
Rob-1995-Mustang-GT is offline
Quick Reply: 90 5.0 cranks but no fire
