Caster Camber Plate Kit
Old 11-19-2013, 07:57 AM
zachary1988
zachary1988's Avatar
Default Caster Camber Plate Kit
I have a 2004 convertible 4.6 and purchased the EIbach Pro Kit. My mechanic suggested that I get the caster camber kit so I can get the car aligned properly. I searched and could not find the correct Eibach kit for the springs. Any help? Thanks in advance. Ed.
zachary1988 is offline
Old 11-19-2013, 01:25 PM
Thatsweetstang
Thatsweetstang's Avatar
How low are you going? Also our cars have a fair amount of camber movement with out the plates. We if you take off your top bearing plate you'll notice it is slotted but has a tab stopping it from sliding, cut the tab off and you'll have a lot more camber movement. If you want camber caster plate then pretty much any of them from 94-04 will work, they are all same. It doesn't matter what springs you have on. Also there are 3 bolt camber caster plates and 4 bolt. I'm a fan of the 4 bolt and use them in our cars because with the 4 bolt ones you have even clamping pressure on the bearing and plate and it doesn't wear out that much, but you have to drill a new hole for the fourth bolt and slot it like the other three. If you go 3 bolt camber caster plate you just need to put it in, no funny business. Just be in mind that if you get a cheap 3 bolt one that you have uneven clamping pressure and in my case it makes a ton of noise over time.
Thatsweetstang is offline
Old 11-19-2013, 10:25 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
This is what you need:
http://www.uprproducts.com/mustang-b...plates-94.html
UPRSharad is offline
Old 11-20-2013, 07:12 AM
zachary1988
Thanks for all of your input. I am using the Eibach Pro Kit and it's not much lowered. 1.3 in front and 1.4 in back. I will go with the caster camber plate. This is a great site. Ed.
Old 11-20-2013, 05:57 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
You're welcome!
Old 11-21-2013, 09:21 PM
71_340
71_340's Avatar
Did you check the Summit and Jegs catalogs....they both have dedicated Mustang sections.
71_340 is offline
Old 11-22-2013, 07:07 AM
zachary1988
Thanks for the tip.
Old 11-22-2013, 10:52 AM
school boy
school boy's Avatar
buy the 4 bolt set, like these. much stronger
http://www.maximummotorsports.com/st...roducts_id=256
http://www.americanmuscle.com/qa1-ccplates-9404.html
I run the qa1 and they are beefy. I really like the mm ones too.
school boy is offline
Old 11-23-2013, 09:12 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
The problem with the four bolt cc-plates is that they aren't a direct bolt on, but we sell those too:
http://www.uprproducts.com/mustang-c...es-4-bolt.html
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
mdg
10-01-2015 07:04 AM
winner99
09-30-2015 07:04 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: Caster Camber Plate Kit
