How to find leaking vaccum
Old 12-10-2013, 05:07 PM
aford89
aford89's Avatar
Default How to find leaking vaccum
I have a 96 GT and i only get the defrost nothing else. I have made sure all the vaccum's were tight on the back of the heat/ac face and i didnt see anything loose when i was changing heater core. Is there an easy way to figure out which is the culprit?
Thanks,
aford89 is offline
Old 12-11-2013, 07:56 AM
Stevo86
Stevo86's Avatar
If you have already looked at the lines inside the dash you need to check the small black line that comes out of the firewall on the passenger side of the engine bay. That's the one that controls your A/C.
Stevo86 is offline
Old 12-13-2013, 01:23 AM
petrock
petrock's Avatar
+1. Its a thin hard plastic tube that comes out of the firewall on the passenger side and goes clear across the engine bay towards the break booster. They often get brittle over time and break. If yours is broken you can repair it by sticking both ends into a small section of rubber hose. I don’t remember the inner diameter of the repair hose, but I picked one up at my local auto parts store.
If your problem is that the hose is broken I’ll look up the specs you need in my factory service manual. Let me know.
Good luck...
petrock is offline
Old 12-13-2013, 09:15 AM
aford89
aford89's Avatar
Good luck...
Got it, took me a min to find cause i kept hearing it goes along firewall in other threads. Mine was just melted apart so went and got some hose all fixed up now
aford89 is offline
mtgldr
02-03-2024 09:00 PM
wawagner82
09-13-2015 09:02 AM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: How to find leaking vaccum
