Need help with this front bumper part
Old 12-15-2013, 08:53 AM
safetyfastgt
safetyfastgt's Avatar
Default Need help with this front bumper part
I have scuffed up the lower black portion of my front bumper pretty bad on one side. It is the black part that juts out a bit just in front of the wheel. It appears to be one piece that goes from one side to the other. It is part number 17A989 on the attached diagram. What I want to know is how difficult it is to replace. Also, there is painted portion at the bottom. Is the painted part a separate piece or will I have to have that section painted onto the part I need? If it is two separate pieces, I would assume it is an easy fix. Finally, are there any screws, clips, etc. I need to also order?
safetyfastgt is offline
Old 12-16-2013, 11:10 AM
Jball001
Jball001's Avatar
here this should help.
http://www.americanmuscle.com/cs-bos...t-install.html
Jball001 is offline
Old 12-16-2013, 07:16 PM
safetyfastgt
That is helpful. Thanks. It's a bit more complicated than expected. I didn't realize I would have to remove the entire front bumper.
Old 12-16-2013, 08:04 PM
alan0614
alan0614's Avatar
Not a big deal to remove the front bumpers on our cars. A few screws and a couple tabs that snap together and you will have it laying on the driveway in no time. Easy directoins are online.
alan0614 is offline
Old 12-16-2013, 09:55 PM
CPTCO
CPTCO's Avatar
Make sure you get some of the stock retainers that hold the inner fender on. I had to break most of mine to get them out.
CPTCO is offline
Old 12-17-2013, 05:41 AM
safetyfastgt
Do I need to get those at the dealer, or are they a common item?
Old 12-17-2013, 09:10 AM
CPTCO
CPTCO's Avatar
They should have them at Napa, Oreilly, etc. they will be all of $.30 a piece, but you've got to have the. The entire process is really easy though, don't let it intimidate you. Take your time.
CPTCO is offline
Old 12-17-2013, 12:15 PM
Jball001
Jball001's Avatar
Yup, just a few clips and bolts. If you follow the instructions it will be very staright foward.
Jball001 is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
cbird1177711
09-03-2015 08:43 PM
Steve@CJPP
CJ Pony Parts
09-03-2015 11:43 AM
Quick Reply: Need help with this front bumper part
