automatic reverse hard jerk
Old 12-19-2013, 07:40 AM
thuxel
thuxel's Avatar
Default automatic reverse hard jerk
I have started to get a hard jerk when I put in reverse. V6 automatic. Approx 94K miles.
Thinking the tranny is starting to go out.
thuxel is offline
Old 12-19-2013, 10:45 AM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Do you have a 2 piece drive shaft? I get a hard jerk when I go into reverse on my '11 and that is due to the crappy OEM 2 piece drive shaft.
Matthew
Matt's 95 Stang is offline
Old 12-24-2013, 01:40 AM
tx_zstang
tx_zstang's Avatar
fluid and filter change ASAP. Your fluid is already probably low, resulting in the harsh reverse engagement.
tx_zstang is offline
Old 12-31-2013, 07:26 AM
J7erry
J7erry's Avatar
There is a NTSB bulletin out on that problem. Check with your dealer
J7erry is offline
Old 01-07-2014, 06:00 PM
amaNIN
amaNIN's Avatar
I get that to but only in warm weather. Is the tranny fluid change covered by the powertrain warranty? If there is a NTSB will that mean it won't cost me or thuxel anything?
amaNIN is offline
Old 01-10-2014, 07:29 AM
teetertotter
teetertotter's Avatar
Just wondering in past years if you are coming to a complete stop when shifting from reverse to drive or doing it as the car is still rolling. And vise versa. My wife is aware of that when she uses her Terrain or others over the years. Just my thought using auto xmissions.
teetertotter is offline
Old 01-11-2014, 01:37 AM
tx_zstang
tx_zstang's Avatar
Usually it's a low/worn fluid issue. If you haven't had your fluid changed by now, you might have damaged the trans. But fluid and filter should help. And it's not a warranty item as it is considered maintenance. Dont let them flush it as part of the change!
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: automatic reverse hard jerk
