Shift issue with my 07 v6 mustang
Old 12-29-2013, 12:57 PM
Patrick Duncan
Patrick Duncan's Avatar
Default Shift issue with my 07 v6 mustang
ok so i have a 2007 4.0 v6 mustang and at first i thought i was having clutch issues so i replaced my clutch slave and throwout bearing. Im still having the same issue so i thought it might be my syncro gears but then i found out reverse dont have a synro. When i shift into 1st or reverse its like its catching on something sometimes at stop lights i cant even get it into 1st i let off the clutch a little and it will fall in 2nd through 5th are catching as well but not like 1st and reverse it gets easier as you go up in gears. Any help would be appreciated!!!! oh and fluids are good checked everything. thanks
Patrick Duncan is offline
Old 12-29-2013, 02:11 PM
pascal
S197 Section Modder-ator
pascal's Avatar
It's the nature of the beast with the POS T5 in those cars. The GT cars have a much better unit.
Those trannies are never smooth from day one and after 50K miles or so, they're just a bitch to engage when not rolling.
The factory calls for auto fluid in those... some folks go with more expensive oil brands and claim a smoother shifting.
In any case, do not use gear oil as a substitute.
pascal is offline
Old 12-29-2013, 08:52 PM
Patrick Duncan
ok so another words best option is to drop a different tranny in correct? if thats the case what would you recommend?
Old 12-29-2013, 09:26 PM
Patrick Duncan
is the t45 a better tranny then the t5 and will it mount with no modifications? im just looking to get a smooth shift and thanks again
Old 12-30-2013, 07:17 PM
pascal
pascal's Avatar
The T45 is a much better transmission but it won't fit in your car, different year etc...
The 3650 that's in the 05/10 GT will work with an aftermarket adapter plate.
The problem is to find a used unit cheap enough.
The 6 speed T56 or T6060 (Shelby unit) will bolt in your car as well with the same adapter plate but those 6 spd are pricy.
Look over at the mustangcollective.com for those swaps, it's been done...
pascal is offline
chrisdbassplayer
10-13-2015 06:53 PM
Dathan
10-05-2015 05:52 AM
degner122
09-16-2015 07:09 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Shift issue with my 07 v6 mustang
