idling issue?
Old 01-05-2014, 10:53 PM
antnvlz1294
antnvlz1294's Avatar
Default idling issue?
I posted a video below, although what the main issue is( if you cant notice in the video, link below) the rpm keeps bouncing as you can see, and it seems to only do this at night when I have my headlights on. Also if you look toward the end of the video, while the rpms are "bouncing" the battery indicator gauge is moving up and down a tiny bit. Ive replaced the stock alternator with a 130 amp 3g. The car is stock but i am receiving no codes... also the car sometimes misfires when the headlights are on usually when im going from 4th to 5th around 45mph, 2-3000 rpm.
http://www.youtube.com/watch?v=S3DyL...ature=youtu.be
antnvlz1294 is offline
Old 01-05-2014, 11:53 PM
H0SS302
H0SS302's Avatar
For idle issues, check these 3 things:
Idle air control valve (IAC)
Positive crankcase ventilation valve (PCV)
And also, check to make sure you have no vacuum leaks anywhere else.
For your other issues, sounds like you have a loose ground or a short. My guess would be to trace back the wires for the headlights and make sure everything is ok. See if there is any exposed wires etc.
H0SS302 is offline
2007StangV6
01-28-2016 06:09 PM
stangin1996gt
09-21-2015 11:01 AM
LivingInThePast
09-16-2015 12:20 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: idling issue?
