89 mustang 2.3 idle Problem HELP!!!
Old 01-14-2014, 12:29 AM
89stang_2.3
89stang_2.3's Avatar
Default 89 mustang 2.3 idle Problem HELP!!!
Okay i got a 89 mustang 2.3 5 speed. The car has never gave me a problem before till now! Just a few weeks ago the car would die at idle. Once it got down to 1000 rpm it would start to surge and the idle would jump from 500 to 1000 then it would die. It would start up with no problem cold or hot. When i go to take off it would start to jump and then it would take off when i just punch. It would run and drive great once im out of 1st gear but when im driving and if im staying steady at just under 2000 i feel the car acting like its not getting enough air or fuel. I got it to my brothers house and pulled the code on it. Funny thing is that the check engine light has never came on. When i checked it the only codes that popped up was the IAC and EGR. Okay the next day i replaced both of them and its still doing the same thing. Checked the codes again and nothing came up then i checked the compression on each cyl and all of them are at 120 thats good!!!! So I replaced plugs, wires, cap, rotor, ignition coil, distributor, and the TFI. When i did all of that the car was running a little bit better but still acting up. Then i jump to the Vacuum line bought all new hoses and tree. Still acting up. Next i Checked the fuel pressure. At idle the pressure is at between 25 to 28 wen its suppose to be at 30 when its idling. I disconnect the hose from the FPR and the psi would jump to almost 40 with my finger on the hose either way. So i replaced the FPR. The fuel pressure is still the same. Its now holding a idle for a little bit but it still surging and dieing like before. When im at one red light and i go to take off it would just start to jump and carry on and once i just punch it in 1st gear it would clear up it would drive good (still doing like i said in the beginning below 2000) The next light it would take off fine. but still idle like S**t. Everything Ive done to it so far the car has inprove. What else can it be PLEASE HELP!!!
89stang_2.3 is offline
Old 01-14-2014, 05:09 AM
I responded to your other post on this issue in the 5.0 section, I didn't see this post till now, but I copied what I wrote about it here.
" If your fuel pressure is still low then I suggest possibly a new fuel filter , or a new pump. You should be getting 35-40 psi at idle with the vacuum hose connected. I suspect its starving for fuel until you drop the hammer , then the vacuum drops off and closes the fpr. "
Old 01-14-2014, 11:31 AM
89stang_2.3
Sorry about that!!! Last night my lap top was acting stupid and every time ill go to summit something on the 2.3/4cyl side it just kept on saying error!!!
But okay ill buy a fuel filter first and see what that will do!!!
djbigskrilla
09-20-2022 01:04 AM
msavoia23
12
07-07-2018 12:08 PM
stanngg
08-12-2015 03:43 PM
daytooday
08-11-2015 09:22 AM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: 89 mustang 2.3 idle Problem HELP!!!
