The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Getting a new engine
Old 01-22-2014, 01:14 PM
bluebeastsrt
bluebeastsrt's Avatar
Default Getting a new engine
Well guys it's time to junk the stock 5.0 for something bigger. The 5.0 did good. It ran in the 10s on spray and low 12s off. I'm moving up to a fully forged 363 Dart shp short block most likely from Fordstrokers. I'm thinking somewhere in the 10.5-11 to 1 compression range. I'll reuse my 190 CC heads and run a 750 CFM dominator carb. It's slow as hell in the SS section so lets hear predictions for what the new set up will run on motor and the 200 shot? ET & MPH guesses.
bluebeastsrt is offline
Old 01-22-2014, 01:56 PM
shinerttu
shinerttu's Avatar
9.7s at 136mph. Lol don't know enough about that engine to estimate the hp, so just a random guess!
shinerttu is offline
Old 01-22-2014, 07:41 PM
bluebeastsrt
probably not a bad guess on the spray.
Old 01-23-2014, 05:38 AM
Stone629
Stone629's Avatar
Definitely be in the 9s. I dont know much about that motor either. What are your guesses, BB?
Stone629 is offline
Old 01-23-2014, 06:39 AM
PurpleIcedGT
PurpleIcedGT's Avatar
9.8 @ 140 on 200 pill of juice
11.6 @ 125 on motor
That is going to be one badass ride BB!
PurpleIcedGT is offline
Old 01-23-2014, 06:52 PM
Explosive
Explosive's Avatar
Did it pop or just building another? Are you on stock internals ? How much have you been spraying it? Are they hyper pistons ?
Explosive is offline
Old 01-23-2014, 08:55 PM
bluebeastsrt
im going with 10.9@122 motor and 9.7@136 spray.
It held together. Its stock bottom end. Pistons were also stock. I sprayed it one time with the full 200 shot and about 8 times on the 50. Never got a roll bar so couldnt go all out without getting booted.I had electrical gremlins like you wouldnt believe so sinse im going carb ill do everything all at once. New motor. Rip out all the fuel injected crap and simplify things.
Old 01-24-2014, 05:13 PM
Mishri
Mish-ogynist
Mishri's Avatar
Should just put a coyote in it, then your problems will be over. get the REALDEAL 5.0
Mishri is offline
Old 01-24-2014, 05:53 PM
bluebeastsrt
Ahhhhhh why settle for a smallish 5.0 when you can have 5.9. Ask any chic they'll tell ya bigger is better.
Old 01-24-2014, 10:35 PM
Stone629
Stone629's Avatar
5.0 coyote is a well engineered engine, but it has absolutely nothing on that 363 Dart. Not even in the same league.
Stone629 is offline
Quick Reply: Getting a new engine
