Fuel pump,injectors,maf upgrade for supercharger?
Old 02-01-2014, 03:25 AM
IvanFiveLiter
IvanFiveLiter's Avatar
Default Fuel pump,injectors,maf upgrade for supercharger?
I will be supercharging my fox soon and debating on what injectors and fuel pump I should get as well as if I should upgrade the mass air and throttle body. Currently sporting 24# injectors 195 pump, 70mm tb, 73 mm mas air. 255 walbro pump or a 340 aeromotive? 36# injectors or trickflow 44's on latemodelrestoration listed for 399.99.
IvanFiveLiter is offline
Old 02-01-2014, 11:13 AM
reldla1996
reldla1996's Avatar
You're going to need to specify what type of s/c, and your hp goals to intelligently discuss your questions. The MA should be up-sized for sure. What heads and intake are you running?
reldla1996 is offline
Old 02-03-2014, 02:10 AM
IvanFiveLiter
S-trim, in the 400-450 rwhp range, trickflow twisted wedge, trickflow street manifold.
Old 02-05-2014, 05:47 PM
STORMTROOPER92
STORMTROOPER92's Avatar
Mass Air i would go with a 80mm Pro-m,(if you can find #42 injectors)255 walbro will be good for you as well.
and budget for a dyno tune as well
STORMTROOPER92 is offline
Old 02-05-2014, 09:06 PM
reldla1996
reldla1996's Avatar
Stormtrooper's recommendations would be the minimums that will work for what you're stating. Larger MA would be a plus. 70mm TB is a little small, but with the s/c, it can work. A good flowing exhaust will be important, and 1 3/4" long tube headers would help.
1TUFF302
11-05-2015 04:02 PM
TfcCDR
09-14-2015 12:08 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Fuel pump,injectors,maf upgrade for supercharger?
