Brake Lines
Old 02-18-2014, 09:18 AM
Djohnson3000
Djohnson3000's Avatar
Default Brake Lines
Hi,
I need to replace the brake lines completely on my 1970 Mach I and the question asked is "what is size of Differential (rear) 8" or 9" How can I tell?
Thanks in advance
Djohnson3000 is offline
Old 02-18-2014, 11:25 AM
clowe1965
clowe1965's Avatar
This is an 8"
clowe1965 is offline
Old 02-18-2014, 11:28 AM
Djohnson3000
Thanks I will look at mine but I wonder is there something I can measure to be certain? What would be the starting point of measurement I wonder.
I appreciate you taking the time to post
Old 02-18-2014, 01:42 PM
clowe1965
clowe1965's Avatar
Look at the third member, it should be roughly octagonal, where the 9" is closer to a true circle. Also the bottom two bolts in the 6 and 8 oclock positions cannot be removed with a ratchet, only a open ended wrench on a 9 inch.
Old 02-18-2014, 03:01 PM
67mustang302
67mustang302's Avatar
What does the differential have to do with your brake lines? Are you trying to get lines pre bent to the exact shape of your housing?
I always just buy bulk line from NAPA a bit longer than I need, and cut/flare one end to get the right length.
67mustang302 is offline
Old 02-18-2014, 06:58 PM
Djohnson3000
Thanks for the feedback will check it out.
Yeah getting pre-bent. Did some reading and flaring and bending seemed to cause lots of issues if not done right and I have never tried so in this case I figured I would go with kit
Old 02-18-2014, 07:40 PM
clowe1965
clowe1965's Avatar
Depending on how much of it you are replacing it's cheaper for the prebent kits when you buy the bender, flaring tool, cutter and a few extra feet of tubing and fittings doesn't pan out. If you're going to do it more than once then buy the tools. I plan on buying them but I've also got a lot of time to do it.
TCStangerv6
10-11-2015 05:57 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Brake Lines
