Tires Smell Like Burning Plastic
manual or automatic? If it's a manual, is this your first manual car? Could be you're slipping the clutch too much and burning your clutch out. Very easy to do in city driving with stop and go traffic.
Try going onto the freeway fro a short stint and pulling off but avoid using the clutch too much, see if the smell decreases, if it doesn't then I'd say tires, if it does, clutch....
I highly doubt its the tires. How new is the car? Is this the first-time that the heat has been used in the car? With the cold winter we've been having I wouldn't be surprised. It can take a few heater uses to get rid of that "new plastic" smell from the heater vents and heater core.
It's a 6 speed manual w/4,500 miles and I think the responses have probably nailed it with a clutch issue as I am doing a lot of stop & go driving. I'll just have to adjust my foot work. Much thanks to everyone for your help.
That is exactly what I thought happened as I ran over a bag and the smell was exactly like a bag burning but it lasted too long I thought ( a couple weeks off and on). I looked but not directly under the frame and did not see anything but you can't see much from above. If it is the clutch then clutches are much more sensitive than so I drove 30 years ago. I do too much stop and go driving but the car should not act up if all is right. I launch at about 1,000 to 1,200 rpm from a stop. I have not smelled it lately so maybe all is good
LivingInThePast
09-16-2015 12:20 PM
tj@steeda
Steeda Autosports
09-08-2015 11:50 AM
