351 Cleveland heads on a 302?
Old 03-31-2014, 08:25 PM
GHILLIE STEW
GHILLIE STEW's Avatar
Question 351 Cleveland heads on a 302?
Hi, okay so i hope i can explain this without it being confusing...I have a 1985 302 block in my '66 Mustang. On this block it appears that i have 351 Cleveland heads, i say this because the exhaust bolts pattern is diagonal instead of straight across...i cannot find any 351W or 302 block haeds that have this bolt pattern. The problem is my valve springs are directly in line, and i cannot find 351C heads that dont have the valve springs offset either...Now down to the questions:
Does this make my engine setup that of a boss 302 motor?
Is this setup more efficient than say having aftermarket 302 heads?
I had the engine bored out .040 over(bad pitting on the cylinder walls), with these heads am i going to have terible overheating problems because of the added compression/higher flow valves?
Generally i am just looking for some advice, im new to this whole car restoration business and i dont want to screw it all up. Thanks to anyone whom has an input. Remember no reply is unwanted, im seriously just trying to get some opions for the experts.
GHILLIE STEW is offline
Old 03-31-2014, 09:06 PM
GHILLIE STEW
Default EDIT
Advice from the experts, not for them...
Old 03-31-2014, 11:07 PM
barnett468
barnett468's Avatar
are the heads aftermarket?
are they aluminum?
whatever heads they are there will be a name or part number on them. it might be under the valve cover
barnett468 is offline
Old 04-01-2014, 12:20 AM
67mustang302
67mustang302's Avatar
Didn't some of the SVO heads have diagonal patterns?
67mustang302 is offline
Old 04-01-2014, 10:36 AM
GHILLIE STEW
The heads are aftermarket im assuming, they sure didn't come one the engine, and they are aluminum...
They were painted years back, i cannot find a part number anywhere, but i suppose im not looking good enough, will recheck and reply.
Old 04-01-2014, 10:42 AM
69mach1377
69mach1377's Avatar
Being aluminum is a good thing, but without specific head data it's hard to tell if they an asset to your build.
69mach1377 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: 351 Cleveland heads on a 302?
