Trunk release problem
Old 04-01-2014, 08:27 PM
BlueBellThunder
BlueBellThunder's Avatar
Default Trunk release problem
On my 2010 mustang I'm having a problem with the trunk release. When I hit the button the motor makes a grinding sound for a few seconds instead of just the click sound. Has anyone had this problem, and have a solution. I don't want to get fleeced by the dealer if I can help it.
Thanks for all replies.
BlueBellThunder is offline
Old 04-01-2014, 08:33 PM
Nuke
Nuke's Avatar
I believe it's a solenoid. I'd try to hit it with some lube or perhaps it's just an adjustment. Have you looked at it?
Nuke is offline
Old 04-01-2014, 08:45 PM
BlueBellThunder
Noting looks out of place. However I'm not that mechanically inclined. I'll try some WD 40, and see if that helps.
Thanks.
Old 04-01-2014, 08:49 PM
Nuke
Nuke's Avatar
IF WD40 does help, then follow that up with a real lubricant. WD40 is a better solvent than lube.
Nuke is offline
Old 04-02-2014, 07:12 AM
JimC's Avatar
When my wife's Focus did that it turned out to be a misalignment of the trunk latch. Adjusted it and never happened again.
JimC is offline
Old 04-07-2014, 03:19 PM
FordService
Official Ford Rep
FordService's Avatar
Hello BlueBellThunder,
I recommend you bring it in to your dealer and speak to your service manager, as he is in the best position to look into this for you and can check into any warranty, assistance, recalls, or customer satisfaction programs that may apply to your vehicle.
Also, remember most repairs done at a Ford Dealer come with a 24 months/unlimited miles warranty. You can schedule an appointment online here.
Deysha
FordService is offline
Old 06-01-2014, 08:23 PM
On The Internet
On The Internet's Avatar
Default 1 particular case of trunk latch malfunction
So I have a similar (or maybe the same) problem. I have an '05 GT Mustang that every now and then makes a "ratchet" sound. As stated by someone it's the electric solenoid that is actuating repeatedly because the trunk lid won't open (initially at least). Could be my imagination, but hot days tend to be worse. I checked the springs on my trunk lid that push the lid open an inch or so. They felt springy so I don't think they are the problem. From what I've read elsewhere the '10 model has a different way to push the lid open an inch.
In my case it looks like maybe a misalignment has been damaging the latch mechanism slowly over time, or perhaps the device was poorly designed. It almost looks like a washer needs to be placed on the latch axel to move the latch further away from the housing as you can see in the picture that the latch is being etched by the housing.
My solution has been to apply, "Valvoline: Ford-Lincoln-Mercury, Moly Fortified Multi-purpose grease" to the inside of the housing between the latch and the housing. If anyone has better lubricant idea, please let us know. Anyway, it really doesn't take any tools to do the job. I used a flathead screw driver, grease, and a zip tie to apply the grease. Oh and a towel. Don't forget to bring a towel. Pictures should give an idea of what I did.
Since this has been an intermittent problem and it being 1 hour since I worked on it I can't say it is a sure fix yet but I'm gettin' good vibes.
Attached Thumbnails Trunk release problem-img_0001.jpg   Trunk release problem-img_0002.jpg   Trunk release problem-img_0003.jpg   Trunk release problem-img_0004.jpg
On The Internet is offline
Old 06-01-2014, 09:05 PM
On The Internet
Default Attachments?
Think I failed with the attachments. Let me try this again...
Attached Thumbnails Trunk release problem-1.jpg   Trunk release problem-2.jpg   Trunk release problem-3.jpg   Trunk release problem-4.jpg
Old 07-16-2014, 11:11 PM
sleslie17
sleslie17's Avatar
Thanks for the ideas guys. I now its been a while since this post originated. Got an '07 that does this - its sounds like a continuous ratcheting noise for up to 3 seconds - very loud. Getting ready to sell the girl so have to get this little thing fixed. Cheers, Shawn
sleslie17 is offline
FivePointToTheOh
03-09-2020 10:26 PM
pimp2303
09-17-2015 08:45 PM
tj@steeda
Steeda Autosports
09-17-2015 07:57 PM
movielover40
09-15-2015 10:37 AM
tj@steeda
Steeda Autosports
09-08-2015 11:50 AM
Quick Reply: Trunk release problem
